Solve Logarithmic Equation: log(x-1) = log(x-2) - log(x+2)
  • Thread starter anil
  • Tags
    Logarithms
In summary: Originally posted by Tom In summary, anil was able to solve the equation log(x-1)=log(x+2)-log(x+2) using the hint that should have unlocked the problem. However, he was also able to solve it using the hint that log(x-1)=log(x-2)/(x+2).
anil
30
I need help on a lograrith HM:
Solve for X: log(x-1)=log(x-2)-log(x+2)
I got till here: log(x-1)=(log(x-2)/(x+2))
Donot know what to do after wards
***Hey if you could tell me the answer please tell me how you derived it. i want to understand the problem. And Base if course to the 10.
Hi anil,
I'll give you a hint that should unlock the whole problem for you.
log(a)-log(b)=log(a/b)
You can apply that to the right side, and then take the antilog of both sides.
Hi anil,
:) ah tom, he has already done that
its after that he is stuck :)
to antilog:
Since the bases are the same (log e), raise both sides to the power of e. This will eliminate the log e on both sides leaving you with a simple equation to solve.
To Tom: As Cummings pointed out, the anil had already done the
log(x-1)= log((x-2)/(x+2)) part.
To Cummings: anil also said "And Base if course to the 10."!
Actually it doesn't matter: as long as a function is "one-to-one" (and logarithm to any base is one-to-one) if f(x)= f(y) then x= y.
Since log(x-1)= log((x-2)/(x+2)) we have x-1= (x-2)/(x+2). Now multiply both sides by x+2 to get (x+2)(x-1)= x-2 so you have the quadratic equation x<sup>2</sup>+ x- 2= x-2. You ought to be able to solve that easily!
Yeah
Actually i solved it like this:
log(x-1) = log(x-2)-log(x+2)
log(x-1) = log((x-2)/log(x+2))
10^log(x-1) = 10^log((x-2)/(x+2))
(x-1) = (x-2)/(x+2)
(x-1)(x+2) = (x-2)(x+2)/(x+2)
x^2+2x-x-2 = (x-2)
x^2+(x-2) = (x-2)
x^2+(x-2)-(x-2) = (x-2)-(x-2)
x^2 = 0
sqrt(x^2) = sqrt(0)
x = 0
But if you Plug o back in Log(0-1) = not possible in real values? So that's is an extraneous solution?
No fair, he edited that part in as I made my comment. :frown:
(See how his edit and my post are 1 second apart?)
Sorry Tom
I posted it and then i was reading the rules. So it says that post it so that people know you tried. SO i didn't read the post you posted. SOrry tom =(
Okay, Tom, I see now.
(You know it has never occurred to me to go back and edit my mistakes! I'll have to start doing that (and then pretend I didn't make a mistake from the start!)
Anil, you are correct that the equation log(x-1)= log(x+2)- log(x+2) has NO real number solutions.
Related to Solve Logarithmic Equation: log(x-1) = log(x-2) - log(x+2)
1. What is a logarithmic equation?
A logarithmic equation is an equation that contains logarithmic functions. Logarithmic functions are the inverse of exponential functions and are used to solve for unknown variables in exponential equations.
2. How do I solve a logarithmic equation?
To solve a logarithmic equation, you can use the properties of logarithms to simplify the equation and isolate the variable. Then, you can solve for the variable using algebraic methods.
3. What are the properties of logarithms?
The properties of logarithms are rules that can be used to manipulate logarithmic expressions. These properties include the product rule, quotient rule, power rule, and change of base rule.
4. What is the solution to the logarithmic equation log(x-1) = log(x-2) - log(x+2)?
The solution to this equation is x = 3. By using the quotient rule and simplifying the equation, we can isolate the variable and solve for x.
5. Can the solution to a logarithmic equation be negative or zero?
Yes, the solution to a logarithmic equation can be negative or zero. In this equation, the solution is x = 3, which is a positive number. However, in other logarithmic equations, the solution may be a negative or zero value.
  • Precalculus Mathematics Homework Help
  • General Math
  • General Math
