RKD89
- 78
- 1
I want to know how Surface areas enclosed by Cylinders , Cones..etc can be calculated using calculus integration...
In both of those, it would probably be best to use cylindrical coordinates.RKD89 said:I want to know how Surface areas enclosed by Cylinders , Cones..etc can be calculated using calculus integration...
The surface area of a cylinder can be calculated by multiplying the circumference of the base by the height of the cylinder and adding the area of the two circular bases. The formula for surface area of a cylinder is 2πr(h + r), where r is the radius and h is the height.
Lateral surface area refers to the area of the curved surface of the cylinder, while total surface area includes the area of the two circular bases in addition to the lateral surface area. The formula for lateral surface area is 2πrh, while the formula for total surface area is 2πr(h + r).
If the radius of a cylinder is increased, the surface area will also increase. Similarly, if the height of the cylinder is increased, the surface area will also increase. This is because both the radius and height are directly proportional to the surface area of a cylinder.
No, the surface area of a cylinder cannot be negative. Surface area is a measurement of the total area of an object, and it cannot have a negative value.
The surface area of a cylinder and its volume are not directly related. The volume of a cylinder is calculated by multiplying the area of the base by the height, while the surface area is calculated using the circumference of the base and the height. However, both the surface area and volume of a cylinder can be affected by changes in its dimensions.
