The point in the D and H fields
In summary, the London equations can be used to calculate the E and D fields in media that differ in dielectric constant.
Gregg
459
In lectures we have been given:
## \vec{\nabla} \cdot \vec{D} = \rho_{\text{free}} ##
## \vec{\nabla} \times \vec{H} = \vec{J}_{\text{free}} + \frac{\partial \vec{D}}{\partial t} ##
## \vec{\nabla} \times \vec{E} = - \frac{\partial \vec{B}}{\partial t} ##
## \vec{\nabla} \cdot \vec{B} = \vec{0} ##
I need examples to work out why ##\vec{D}## and ##\vec{H}## are such a convenience for me. This is something I can't see at all!
## \vec{D} = \epsilon_r \epsilon_0 \vec{E} ## ? So it should be useful in dielectrics, and ## \vec{D} = \epsilon_0 \vec{E} + \vec{P} ## so polarisation is defined as the E field caused by a relative dielectric constant in some dielectric material?
The there's ## \vec{H} = \frac{\vec{B}}{\mu_0} - \vec{M} ## and also I guess ## \frac{\vec{B}}{\mu_0 \mu_r} = \vec{H}## ? So the magnetisation is the magnetic field due to some medium with relative permeability?
But why are these vector fields useful for calculations?
The basic physical difference between the E and D fields is that the E field represents a force along a line element while the D field represents a flux density through a surface. The spatial relationship between them is simple in a vacuum but not necessarily so in media. The same applies to the H and B fields.
In media that relationship is given by the constitutive relations and it can be challenging to determine given only charge distribution and charge motion, but there are techniques. Without being able to calculate the D field, you would probably not be able to eliminate the degrees of freedom to arrive at a resolution of the constitutive relations.
The alternative would consist in working with the internal current densities J_int. But in contrast to polarization it is not a good approximation to assume that the internal currents are proportional to the internal field (after all J_int=dP/dt). Same for magnetization.
Obviously this does not hold always true. E.g. in superconductors, the internal current is proportional to the local value of the magnetic vector potential
http://en.wikipedia.org/wiki/London_equations
so one won't usually describe a superconductor in terms of D or H fields.
Hi Gregg! :smile:
Imagine an ordinary parallel-plate capacitor with more than one dielectric between the plates.
Calculating the E field directly could be horrendous.
Calculating the D field is really easy (you ignore the dielectrics!), and then just divide by the relevant ε to get E. :wink:
Interesting. Thanks for the reference.
Why does the D field and H field not completely replace the B and E fields then in these equations? Is it not useful to say ## \vec{{\nabla}} \times \vec{D} ## ?
tiny-tim said:
Hi Gregg! :smile:Imagine an ordinary parallel-plate capacitor with more than one dielectric between the plates.
Very good point Tim. I was going to say something along that line but you already said it. So I'll just add a few more words.
If the differing dielectrics are in series, then the D field value is the same for both media. The E values differ, and can be obtained by multiplying the D value, the same for both media, by the appropriate dielectric constant. At the boundary the normal values of D are equal.
If said differing dielectrics are in parallel, then the E field values are the same, the D values differ in proportion to epsilon. The E field is just V/s in the direction perpendicular to the plates. V is the voltage, and s is the spacing between the plates. At the boundary the tangential values of E are equal.
Likewise, a similar relation holds for magnetic fields, H & B, in the presence of differing media. For series media, Bnormal1 = Bnormal2. The H values differ & are obtained from H1 = B1/mu1, & H2 = B2/mu2. At a boundary for parallel media, Htangential1 = Htangential2. Then B values are obtained by multiplying H by the appropriate mu value.
I agree that B, D, E, & H, are all important. Which quantities should be employed is determined by the nature of the problem under scrutiny. For 2 different media in parallel, I determine E & H, then compute D & B by considering the constants epsilon & mu. For 2 media in series, I determine B & D, then compute E & H by considering mu & epsilon.
Did I help? Best regards.
Claude
We can express any and all of Maxwell's equations using any combination of quantities we wish. E.g.: curl E = -dB/dt, can also be expressed as curl D = -epsilon*dB/dt, or if you prefer curl D = -epsilon*mu*dH/dt, then again curl E = -mu*dH/dt.
I don't believe that any of the above is more or less correct, it just happens that I learned ME (Maxwell's equations) in a form I describe as "medium-independent". For Faraday's law using E & B results in no epsilon or mu factor. With Amperes law, using H, D, & J (current density) also results in no factors accounting for relative permittivity/permeability of the medium.
In the case above with the capacitor having more than 1 dielectric material, series or parallel, the use of D as opposed to E is determined by boundary conditions. In series 2 media have equal D values along the normal direction. In parallel 2 media have equal E values along the tangential direction.
I prefer the "lazy approach". I express equations in their simplest "medium-independent" form whenever possible. I would rather have no mu or epsilon appearing in the equation. That being said, we need to examine all 4 quantities, not just 2, because they all convey useful info. I will elaborate further if needed.
Claude
What is the point in the D and H fields?
The point in the D and H fields refers to the location in space where the electric and magnetic fields have the same magnitude and direction, resulting in a balanced electromagnetic wave.
Why is the point in the D and H fields important?
The point in the D and H fields is important because it allows for the propagation of electromagnetic waves, which are essential for many communication and technological systems.
How is the point in the D and H fields determined?
The point in the D and H fields can be determined by using Maxwell's equations, which describe the relationship between electric and magnetic fields and their sources.
Can the point in the D and H fields change?
Yes, the point in the D and H fields can change depending on the strength and direction of the electric and magnetic fields, as well as the properties of the medium through which the fields are propagating.
What is the relationship between the point in the D and H fields and electromagnetic waves?
The point in the D and H fields is where the electric and magnetic fields are in phase and perpendicular to each other, creating an electromagnetic wave that can propagate through space.
  • Quantum Physics
