Torque of human arm when bending
In summary, the necessary torque to bend the arm at 180 degrees, 90 degrees, and 30 degrees can be calculated using the equation τ=rFsinθ and the given information of a total arm weight of 3.35kg, an upper arm length of 19cm, and a forearm length of 28cm. The orientation of the upper arm is also necessary for accurate calculation.
mdp_somebodeh
To find the respective torque that is need to bend the the arm at 180 degrees, 90 degrees and 30 degrees. The arm is not holding anything.
Relevant equations and information
τ=rFsinθ
total arm weight =3.35kg
upper arm length =19cm
forearm length =28cm
welcome to pf!
hi mdp_somebodeh! welcome to pf! :wink:
show us what you've tried, and where you're stuck, and then we'll know how to help! :smile:
(start with 180°)
This is bending at the elbow, right? Don't you need to know the orientation of the upper arm?
sorry, too difficult to read :redface:
can you type it out, please? :smile:
Related to Torque of human arm when bending
1. What is torque and how does it relate to the human arm?
Torque is a measure of rotational force and is defined as the product of the force applied and the distance from the pivot point or axis of rotation. In the context of the human arm, torque is the force generated by the muscles and tendons when bending the arm at the elbow joint.
2. How is the torque of the human arm affected by the weight of an object being held?
The weight of an object being held in the hand can increase the torque on the elbow joint, as the muscles and tendons of the arm must work harder to support the weight. This can lead to fatigue and potential injury if the weight is too heavy or held for an extended period of time.
3. Does the length of the arm affect its torque when bending?
Yes, the length of the arm can affect its torque when bending. A longer arm will have a greater distance from the pivot point, resulting in a larger torque for the same amount of force applied. This is why individuals with longer arms may be able to lift heavier objects or perform certain tasks with less effort compared to those with shorter arms.
4. How does the angle of the elbow joint affect the torque of the human arm?
The angle of the elbow joint plays a significant role in determining the torque of the human arm when bending. When the elbow joint is fully extended, the torque is at its maximum, as the muscles and tendons have to work against gravity to keep the arm in position. As the angle of the joint decreases, the torque decreases as well, making it easier to hold the arm in place.
5. What factors can affect the torque of the human arm when bending?
Aside from the weight of an object and the length and angle of the arm, other factors that can affect the torque of the human arm when bending include the strength and conditioning of the muscles and tendons, as well as the presence of any injuries or disabilities. Additionally, the positioning of the body and the use of proper form and technique can also impact the torque of the human arm when bending.
  • Biology and Medical
  • Mechanical Engineering
