DottZakapa
- 239
- 17
- Homework Statement
- Have two Poisson distributed random variables, with parameter ##\lambda##=2
- Relevant Equations
- probably
How do I evaluate
P(X-Y=0)=?
P(X-Y=0)=?
DottZakapa said:it was a question in a multiple choice question. i was trying to find out why that wasn't the correct answer:
it was stating that
##P \left( X-Y=0 \right)=1##
hence i was trying to compute it
Sometimes it is so surprising to see what details are left out of the official problem statement.etotheipi said:Do you have the verbatim problem statement?
me too but, i want to know/understand why P[X-Y=]=1 is not correct.etotheipi said:Do you have the verbatim problem statement?
DottZakapa said:me too but, i want to know/understand why P[X-Y=]=1 is not correct.
A Poisson distribution is a probability distribution that describes the number of events that occur in a fixed interval of time or space. It is often used to model rare events that occur independently of each other.
A Poisson distribution is characterized by its mean, which represents the average number of events in the given interval, and its variance, which measures the spread of the distribution around the mean. It is also a discrete distribution, meaning that the possible outcomes are whole numbers.
Two Poisson distributed random variables refer to two separate events or processes that follow a Poisson distribution. This means that the number of events or occurrences for each variable can be described by a Poisson distribution with its own mean and variance.
Two Poisson distributed random variables can be related in several ways. They can be independent, meaning that the occurrence of one variable does not affect the other. They can also be correlated, meaning that the occurrence of one variable is related to the occurrence of the other. Additionally, they can be used to model a single event with different parameters, such as the number of customers at two different stores.
The joint probability of two Poisson distributed random variables can be calculated by multiplying the individual probabilities of each variable. This can be represented by the formula P(X=x, Y=y) = P(X=x) * P(Y=y), where X and Y are the two variables and x and y are specific values. Alternatively, a joint probability table or a Poisson distribution calculator can be used to find the joint probability.
