Weight percentage / stoichiometry
From there, you can determine the weight % of the hydrate in the original mixture by dividing the mass of the hydrate by the total mass of the original mixture and multiplying by 100. In summary, by finding the moles of water, you can determine the moles and mass of the hydrate compound in the original mixture, and then use that information to calculate the weight % of the hydrate in the mixture.
lorka150
39
I did this a bunch of times and did not understand what to do. Hopefully someone can shed some light. Our prof gave us hints, but they aren't really helping.
A mixture of KCr(SO3)2 and its hydrate KCr(SO4)2.12H2O has a mass of 1.6336 g. After heating (driving off water), the mass is 1.4659 g. What is the weight % of KCr(SO4)2.12H2O in the original mixture?
Molar mass of KCr(SO4)2 is 283.22 g/mol
Molar mass of KCr(SO4)2.12H2O is 499.40 g/mol.
This is what I tried: I figured the mass of water was 0.1677g, and therefore the moles were 0.0009306 mol.
Then, the mols of KCr(SO4)2.12H2O is 0.0007755. The mass was that x 499.40, which gave me 0.38728 g.
And then I was lost. I don't know how to utlize the molar mass of KCr(SO4)2 in this question, either.
Thanks!
You need to utilize the information for the water in this problem, by finding the moles of water, you can find calculate the moles of the hydrate compound, and then the grams.
First, it's important to understand that weight percentage and stoichiometry are related concepts. Weight percentage is a measure of the amount of a particular substance in a mixture, while stoichiometry is the quantitative relationship between the reactants and products in a chemical reaction.
In this problem, we are given a mixture of KCr(SO3)2 and its hydrate KCr(SO4)2.12H2O, and we are asked to find the weight percentage of the hydrate in the original mixture.
To do this, we need to use stoichiometry to determine the amount of KCr(SO4)2.12H2O in the original mixture. We can do this by considering the mass of the mixture before and after heating, as well as the molar masses of both compounds.
First, we can calculate the mass of KCr(SO3)2 in the original mixture by subtracting the mass of KCr(SO4)2.12H2O (1.4659 g) from the total mass of the mixture (1.6336 g). This gives us a mass of 0.1677 g for KCr(SO3)2.
Next, we can use the ratio of molar masses to determine the moles of KCr(SO3)2 and KCr(SO4)2.12H2O in the mixture. Since the molar mass of KCr(SO4)2 is 283.22 g/mol and the molar mass of KCr(SO3)2 is 270.19 g/mol, we can set up the following equation:
0.1677 g KCr(SO3)2 / 270.19 g/mol = x g KCr(SO4)2 / 283.22 g/mol
Solving for x, we get a mass of 0.1606 g for KCr(SO4)2 in the original mixture.
To find the weight percentage of KCr(SO4)2.12H2O in the original mixture, we can divide the mass of KCr(SO4)2.12H2O (0.1606 g) by the total mass of the mixture (1.6336 g) and multiply by 100%. This gives us a weight percentage of approximately 9.8%.
In summary, by using stoichiometry and the molar masses of the compounds involved,
Related to Weight percentage / stoichiometry
1. What is weight percentage?
Weight percentage, also known as weight percent or wt%, is a way of expressing the concentration of a solute in a solution. It is calculated by dividing the mass of the solute by the total mass of the solution and multiplying by 100.
2. How is weight percentage used in chemistry?
Weight percentage is commonly used in stoichiometry to determine the amount of a substance needed in a reaction. It is also used in analytical chemistry to measure the purity of a substance or the concentration of a solute in a solution.
3. What is the difference between weight percentage and mole percentage?
Weight percentage is based on the mass of the solute and the total mass of the solution, while mole percentage is based on the number of moles of the solute and the total number of moles in the solution. This means that weight percentage can change depending on the molecular weight of the substance, while mole percentage remains constant.
4. Can weight percentage be greater than 100%?
No, weight percentage cannot be greater than 100%. It represents the proportion of the solute in the solution, so a weight percentage of 100% means that the entire solution is made up of the solute.
5. How can weight percentage be converted to other units of concentration?
Weight percentage can be converted to other units of concentration, such as molarity or molality, by using the molecular weight of the solute. The weight percentage can be multiplied by the total volume of the solution (for molarity) or the mass of the solvent (for molality) and then divided by the molecular weight to get the desired unit of concentration.
