Dhruv
- 27
Can someone explain me what are high field domain or can give me a source from where I can understand it.It will be very helpful.
High field domains in GaAS diode refer to regions within the diode where the electric field is significantly higher than the average electric field. These domains can form due to the presence of defects or impurities in the diode material.
High field domains can negatively impact the performance of GaAS diodes by causing local breakdown, which can lead to device failure. They can also affect the diode's overall efficiency and introduce parasitic capacitance.
High field domains can be caused by a variety of factors, including crystal defects, impurities, and non-uniformities in the diode material. They can also be induced by high voltage or high current operation.
High field domains can be reduced by improving the quality and purity of the diode material, optimizing the diode's design and fabrication process, and implementing proper device packaging and cooling techniques.
High field domains in GaAS diodes can be intentionally created and controlled to achieve specific device characteristics, such as high breakdown voltage or high frequency operation. They can also be used in nonlinear devices, such as oscillators and mixers.
