Guineafowl
- 762
- 366
Old-fashioned fuse wire comes rated at 5, 15 and 30A. The equivalent MCBs (breakers) are rated 6, 16 and 32A.
Is there a reason for this difference?
An MCB has two functions: overcurrent heating a bimetallic strip and a solenoid that actuates with very fast rise times, as in a dead short.CWatters said:Not 100% sure but I thinks it's because fuses tollerate slightly higher short term currents. Eg they blow at 30A continuous but tollerate 32A for short periods.
Edit: Think that might be wrong because type B MCB actually trips at 3-5 times the rated current.
MCBs and fuses are both electrical protection devices used to prevent overloading and short circuits in a circuit. However, they function differently and therefore have different ratings. MCBs are rated based on their breaking capacity, which is the maximum current they can safely interrupt without damage. Fuses, on the other hand, are rated based on their current-carrying capacity, which is the maximum current they can safely handle without overheating. This is why the ratings for MCBs and fuses are not directly comparable.
MCBs use an electromechanical tripping mechanism, which means they detect an overcurrent and trip the circuit by physically opening the contacts. Fuses, on the other hand, use a thermal tripping mechanism, where the fuse element heats up and melts to interrupt the circuit. This difference in tripping mechanism also affects their ratings, as MCBs can typically handle short surges of current better than fuses.
Yes, both MCBs and fuses are designed to protect against overcurrent and short circuits in a circuit. However, MCBs can also provide additional protection against other types of faults, such as earth leakage and overload, depending on their type and features.
No, MCBs and fuses cannot be used interchangeably. As mentioned earlier, they have different ratings and tripping mechanisms, and therefore serve different purposes. It is important to select the appropriate device for the specific circuit and its requirements.
In general, MCBs tend to be more expensive than fuses. However, they also offer more features and benefits, such as easier reset and better protection against multiple types of faults, which can make them a more cost-effective choice in the long run. It ultimately depends on the specific needs and requirements of the circuit.
