Why does induction in a loop depend on the contained flux?
In summary,It appears odd to me that it is the change of flux through the contained area that matters, rather than the flux that goes through the loop/wire itself. Why would the electrons in the loop be affected when more/less flux passes straight through the middle of the loop, possibly in a region that doesn't even touch the wire?Does anyone have a good explanation? Thanks!
Xilor
152
Hiya,
I'm struggling to find/figure out some kind of intuitive explanation why it is the changing flux of the contained area that matters for Faraday's law of induction. It appears odd to me that it is the change of flux through the contained area that matters, rather than the flux that goes through the loop/wire itself. Why would the electrons in the loop be affected when more/less flux passes straight through the middle of the loop, possibly in a region that doesn't even touch the wire?
Would something like a galaxy sized loop still display this behavior? That sounds bizarre
Bizarre indeed, isn't it? A question like yours has inspired A Einstein to come up with his "Zur Elektrodynamik bewegter Koerper" . Goes to show great minds think alike :smile:.
Read what Feynman and Albert himself have to say about this.
The two phenotypes are https://www.boundless.com/physics/textbooks/boundless-physics-textbook/induction-ac-circuits-and-electrical-technologies-22/magnetic-flux-induction-and-faraday-s-law-161/changing-magnetic-flux-produces-an-electric-field-572-6061/: the integral and differential form of the Maxwell-Faraday equation.
Worth studying: geniuses at work.
Likes cnh1995 and Xilor
Thanks for the links! Glad to hear it isn't a case of missing something very basic haha
So, looking at your links (the boundless.com one specifically), it seems the differential form doesn't include the area anymore, is that correct? That makes it sound to me like that means the flux of the area inside isn't 'actually' relevant, it's just that the area term appears if you transform the differential form further. Is that a correct interpretation? Or am I getting even further off the track?
Still on track. Link between the diff and int form is Stokes' theorem. Just math :rolleyes:. Easier for the Gauss law Maxwell equation than for the Faraday one ( at least for me it requires some more googling -- or a textbook).
It is a very interesting question. Think emf and flux are integrals of the fields. Magnetic field inside the loop, and electric field around the loop. So in this law while you integrate information of the field is lost but it helps to solve problems that have some symetry. As you said in Maxwell equation there is no need to involve area. Is my way to think of it hope it helps.
Likes cnh1995 and BvU
So to continue the track, since the change of flux is still relevant in the differential form, we are then actually talking about the change of flux that happens in the wire? Or does the change still 'count' the changed flux in the area in between?
Hmm, actually I suppose it would still have to account for the area in between, otherwise you could easily get an inconsistent result with the area based function. If you have some closed loop, and bend the left side rightwards, then the area decreases so the flux decreases, but if you bend the right side rightwards, the area increases and so would the flux, so the current would flow in opposite directions. But from the perspective of the local wire, you're moving it rightwards in both cases, so there shouldn't be a good reason for them to have the current flowing in opposite directions, since the local wire obviously doesn't know anything about the location of the rest of the wire.
Hmm, so how is this possible? That some of the information (the area) appears to play a role in one function, yet when it is 'lost' in the differential function results still work out perfectly, even though it actually appears to still be necessary (see the example above).
That one is easiest to grasp when you look at the Lorentz force: emf is induced in the same direction in the section that moves, whether left or right. But the effect is opposite (cw or acw).
Ah of course, I can't believe I missed that. Alright thanks! That clears that up
Related to Why does induction in a loop depend on the contained flux?
1. Why does induction in a loop depend on the contained flux?
Induction in a loop depends on the contained flux because of Faraday's law of electromagnetic induction. This law states that the induced electromotive force in a closed loop is directly proportional to the rate of change of magnetic flux through the loop.
2. What is flux and how does it relate to induction in a loop?
Flux is a measure of the amount of magnetic field passing through a given area. In the context of induction in a loop, it refers to the magnetic field passing through the loop. The greater the flux, the stronger the induced electromotive force in the loop.
3. Does the size or shape of the loop affect induction?
Yes, the size and shape of the loop can affect induction. A larger loop will have a greater surface area for the magnetic field to pass through, resulting in a larger induced electromotive force. Similarly, a loop with a different shape may have a different distribution of magnetic flux and therefore a different induced electromotive force.
4. Can the direction of the magnetic field affect induction in a loop?
Yes, the direction of the magnetic field can affect induction in a loop. According to Lenz's law, the induced electromotive force in a loop will be in a direction that opposes the change in magnetic flux. This means that if the direction of the magnetic field changes, the direction of the induced electromotive force will also change.
5. How is induction in a loop used in practical applications?
Induction in a loop is used in a variety of practical applications, including generators and transformers. In generators, the rotation of a loop in a magnetic field induces an electromotive force, which can then be converted into electrical energy. In transformers, induction is used to transfer electrical energy from one circuit to another through a changing magnetic field.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
