How Does Quantum Mechanics Relate to Quantum Field Theory in Particle Physics?
  • Context: Undergrad
  • Thread starter Thread starter fxdung
    Qft Qm Relation
The discussion centers on the relationship between quantum mechanics (QM) and quantum field theory (QFT) within the context of particle physics. Participants explore the foundational principles of both theories, their interconnections, and the implications for understanding particle behavior and interactions.
  • Some participants assert that QFT is based on QM, suggesting that QFT can be viewed as an application of QM to fields.
  • Others express uncertainty about why QFT must involve QM, noting that while they do not contradict each other, QM cannot be directly deduced from QFT.
  • Concerns are raised regarding the absence of explicit references to QM principles in QFT textbooks, particularly in relation to the S-matrix and Feynman diagrams.
  • Participants discuss the role of commutation relations in QFT and question how they relate to the principles of QM, particularly regarding wave functions and observable quantities.
  • Some argue that the path integral formulation is central to both QM and QFT, highlighting its foundational role in understanding quantum systems.
  • There is mention of the Second Axiom of QM and its applicability to QFT, with some suggesting it is not explicitly used in QFT treatments.
  • Discussions include references to non-contextuality and Gleason's theorem, with participants seeking further resources on these topics.
  • One participant emphasizes the complexity of the relationship between QM and QFT, suggesting that it is not straightforward and varies across different treatments in textbooks.
Participants do not reach a consensus on the relationship between QM and QFT. There are multiple competing views regarding the necessity of QM in QFT, the interpretation of foundational principles, and the implications of various mathematical formulations.
Limitations include the lack of clarity on certain foundational axioms of QM in the context of QFT, as well as the absence of detailed steps in advanced treatments that could bridge the two theories. The discussion also highlights the dependence on specific definitions and interpretations of key concepts.
  • #121
A. Neumaier said:
Something in ths statement is strange since cumulants are numbers, not operators, so they commute with everything.
I know of different ways to ''get'' the result you want from appropriate versions of the Born rule. But the ''derivations'' in the textbooks or other standard references I know of are all questionable. The challenge is to provide a derivation for which all steps are physically justified.
I was thinking of doing like you did above, so that the variance is ##\sigma_A=\sqrt{\langle (A-\langle A \rangle)^2\rangle}##.
Actually, there is a different definition of the Born rule eg. http://arxiv.org/abs/1110.6815 given as rule II.4 on p8:
##p_{x} = Tr [P_{x} \rho P_{x}]##
But I have always assumed the two forms are equivalent.
  • #122
Demystifier said:
I was not sufficiently precise. What I meant is that in some interpretation only one of the pictures may be appropriate. For example, in the many-world interpretation only the Schrödinger picture is appropriate.
As I said, that cannot be. Both pictures are completely equivalent. So the interpretation about the relation of the formalism to observations in physics cannot depend on the picture of time evolution used (modulo mathematical problems a la Haag's theorem concerning the non-existence of the interaction picture of relativistic QFT; here you have to take the common practice of using the perturbative (partially resummed) evaluations of S-matrix elements, being compared to measured cross sections and spectral shapes of unstable resonances with the usual renormalization prescriptions as the theory).
Admittedly, I've never understood the point of the many-worlds interpretation, but if it depends on the choice of the picture, it's not compatible with standard QT.
  • #123
A. Neumaier said:
One can generalize everything to weaken arguments aimed at the ungeneralized version. The conventional axioms of QM say how the state of a system changes through a perfect measurement. [See, e.g., Messiah I, end of Section 8.1, or Landau & Lifschitz, Vol. III, Chapter I, Par. 7.] This is a context that makes sense only in the ordinary Schroedinger picture.
In Landau and Lifshitz (and most probably also in Messiah, which I can't check at the moment) everything is discussed in terms of wave functions, which is a picture-independent quantity, i.e., of the form ##\psi(t,\alpha)=\langle \alpha,t|\psi,t \rangle##, where the state ket ##|\psi,t \rangle## and the eigenvectors of operators ##|\alpha,t \rangle## develop in time with two arbitrary self-adjoint operators ##\hat{X}(t)## and ##\hat{Y}(t)## with ##\hat{X}(t)+\hat{Y}(t)=\hat{H}##, where ##\hat{H}## is the Hamiltonian of the system. These operators define two unitary time-evolution operators through the equations of motion
$$\dot{\hat{A}}(t)=\mathrm{i} \hat{X}(t) \hat{A}(t), \quad \hat{A}(t=0)=1,$$
$$\hat{\hat{C}}(t)=-\mathrm{i} \hat{Y}(t) \hat{C}(t), \quad \hat{C}(t=0)=1.$$
Then
$$|\alpha,t \rangle=\hat{A}(t) |\alpha,t=0 \rangle, \quad |\psi,t \rangle=\hat{C}(t) |\psi,t \rangle,$$
and from that you get for the wave function
$$\psi(t,\alpha)=\langle \alpha,t|\psi,t \rangle = \langle \alpha,t=0 |\hat{A}^{\dagger}(t) \hat{C}(t)|\psi,t=0 \rangle,$$
and thus the equation of motion of the wave function is picture independently given by the usual Schrödinger equation
$$\mathrm{i} \partial_t \psi(t,\alpha)=\hat{H} \psi(t,\alpha),$$
where ##\hat{H}## here stands for the representation of the Hamilton operator in the ##\alpha## basis.
  • #124
The two pictures are not equivalent. They only have the same measurable predictions, just as all interpretations have the same measurable predictions. Of course, you may say that this means that all interpretations are also equivalent, but that would miss the very point of interpretations. The point of interpretations is not merely to make predictions. The point of interpretations is to give an intuitive idea of what is really going on. If some interpretation (such as MWI) says that ##\psi(t)## is a really existing physical quantity (not merely a calculation tool) that really depends on time ##t##, then it makes sense only in the Schrödinger picture. From the MWI point of view, the true physics happens only in the Schrödinger picture, while Heisenberg picture is only a convenient calculation tool.
  • #125
Then
Sure - there is no difference in the treatment of the unitary case. The differences in derivation, claims, and interpretation appear only when discussing measurement, which is interaction with an - unmodelled - detector. Then there is a considerable difference how different authors proceed, unless one copied from the other. My statement was made in the context of a perfect (von Neumann) measurement.
  • #126
I don't know, what you mean by ##\psi(t)##. Is it a Hilbert-space vector representing a pure state? If so, then it's picture dependent. Is it a wave function ##\psi(t,\vec{x})## for a single particle wrt. to the position representation? Then it's picture independent and its physical meaning is that ##|\psi(t,\vec{x})|^2## is probability distribution to find the particle at position ##\vec{x}##. That's observable by making a measurement on an ensemble of equally and stochatically independently (uncorrelated) prepared particles. I think this minimal interpretation of QT, referring to the observable facts (and that's what physics is about and not to "explain the world"), is common to all interpretations of QT. If some interpretation differs from this, it's a new theory, contradicting QT in at least one observable fact, and then this is testable empirically. Any interpretation that claims that you have observable differences depending on the picture of time evolution chosen, claims that QT is incorrect and must be substituted by another theory that prefers one picture over any other. As far as I know, there's no hint that such a modification of QT is necessary.
  • #127
The description of filter preparation procedure (often inaccurately called a "measurement") is also independent of the choice of the picture of time evolution. It is also not defined in terms of abstract mathematical entities of the formalism but by a concrete experimental setup. Any description of a Stern-Gerlach experiment for the "advanced lab" ("Fortgeschrittenenpraktikum") is a paradigmatic example.
  • #128
Everyone seems to make the assumptions that the various forms are equivalent, but few seem prepared to prove it...
The paper by Paris that you cite states on p.2.,
Paris said:
by system we refer to a single given degree of freedom (spin, position, angular momentum,...) of a physical entity. Strictly speaking we are going to deal with systems described by finite-dimensional Hilbert spaces and with observable quantities having a discrete spectrum.
This is an extremely special case of QM, far too special for anything that could claim to be a foundation for all of quantum mechanics. It can serve as a motivation and introduction, but not as a foundation. (And the author doesn't claim to give one.)
If ##X## is a Hermitian operator with a discrete spectrum (which Paris assumes on p.2) then the calculation in Postulate 2 on p.3 is valid and gives a valid derivation of the meaning of the expectation two lines after (1) from the Born rule one line before (1). If the spectrum contains a continuous part, Born's rule as stated in the line before (1) is invalid, as the probability of measuring ##x## inside the continuous spectrum is exactly zero, although a measurement result is always obtained. Instead,
the squared absolute amplitude should give the probability density at ##x##. Wikipedia's Born rule has a technical annex for the case a general spectrum that is formally correct but sounds a bit strange for fundamental postulates (that should be reasonably intuitive). But it is not formulated generally enough since the deduction from it,
wikipedia said:
If we are given a wave function
for a single structureless particle in position space, this reduces to saying that the probability density function
for a measurement of the position at time
will be given by [PLAIN]https://upload.wikimedia.org/math/8/2/b/82b20d585c65a498143e1efda64eefa5.png[PLAIN]https://upload.wikimedia.org/math/9/8/c/98c5c92074973386aa8bca86bde81273.png[/QUOTE]
(which is essentially Born's original interpretation from 1926 - he didn't consider observables other than position coordinates)
doesn't follow but needs even more machinery from functional analysis about the existence of the joint spectrum for a set of commuting self-adjoint operators. it is very strange that the foundations of quantum mechanics should depend on deep results in functional analysis...
Paris goes on to say on p.3,
Paris said:
As it is apparent from their formulation, the postulates of quantum mechanics, as reported above, are about a closed isolated system.
This is incorrect since according to every interpretation of quantum mechanics, the dynamics of an isolated system is always unitary and it cannot be observed, since observation is possible only when the system interacts with a detector.
The correct formulation (in the finite-dimensional case discussed by Paris) should be:
Postulate 2a. As long as a system is isolated the dynamics of its state is given by the Schroedinger equation. During the interaction with an instrument the state changes in such a way that (in the interaction picture) the state of a system in a pure state ##\psi## before the entering the instrument changes upon leaving the instrument with probability ##|P_x\psi|^2## to a pure state proportional to ##P_x\psi##, where ##\sum_x P_x^*P_x=1## (i.e., the ##P_x^*P_x## form a POVM). The ##P_x## are characteristic for the instrument, and can (in principle) be predicted from a quantum treatment of the instrument.
This is the observer-free formulation. It can be complemented by the following assertion involving observation:
Postulate 2b. If the final state is proportional to ##P_x\psi##, one can (in principle) deduce the value of ##x## from observations of the instrument and its surrounding. But the change of state happens whether or not the instrument is observed.
There is a corresponding version for mixed states that involves density matrices (which also needs a replacement of Postulate 1 of Paris). The resulting set of postulates is a much better set of postulates for (finite-dimensional) quantum mechanics. In particular, after an appropriate extension to POVMs with infinitely many components, they (unlike the Born rule) fairly faithfully reflect most of what is done in modern QM.
A mutilated, unnecessarily rigid and subjective form of the postulates in the density matrix version was stated by Paris on p.9. Note that in this process he completely changed the postulates! Postulate 1 (pure states) was silently dropped on p.4 where he remarks that ''different ensembles leading to the same density operator are actually the same state, i.e. the density operator provides the natural and most fundamental quantum description of physical systems''. (How can something be more fundamental than the very foundations one starts with? How can obviously different ensembles, if they mean anything physically, ''actually be the same state''? Only by changing the notion of a state.) Postulate 3 (unitarity) is dropped on the same page by observing that ''the action of measuring nothing should be described by the identity operator'', while according to Postulate 3 it should be described by the Hamiltonian dynamics. (He is assuming an interaction picture, without mentioning it anywhere!) Finally, Postulate 2 (the definition of an observable and the Born amplitude squaring rule) is replaced by a new definition of observables in II.1 and a generalized Born rule II.3 that was invented only much later (probably around the time Born died). In II.5 he adds a rule that is in direct conflict with II.3 since a measurement performed in which we find a particular outcome cannot lead to two different states depending on whether or not we record the result.
Thus Paris documents in some detail that modern quantum mechanics is, fundamentally, neither based on state vectors nor on observables being Hermitian operators nor on instantaneous collapse nor on Born's rule for the probability of finding results. Instead, it is based on states described by density matrices, observables described by POVMs, interactions in finite time described by multiplication with a POVM component, and a generalized Born rule for the selection of this component. This generalized setting is necessary and sufficient to describe modern quantum optics experiment at a level where efficiency issues and measuring imperfections can be taken into account.
Apart from the Hilbert space, nothing is kept from the textbook foundations, except that the latter serve as a simplified (but partially misleading) introduction to the whole subject.
  • #129
For me, physics is about both. But of course, anybody has freedom to use physics for whatever one wants.
  • #130
That's just an example of the general principle: The axiomatization of the theory, so natural in mathematical physics, is often not a good idea in theoretical physics. Theoretical physics should be open to frequent modifications and reformulations.
  • #131
I agree with that, but to me, it seems that the switch from idealized measurements whose outcomes are eigenvalues with probabilities given by the Born rule to the density matrix interpretation is not such a big deal. It's important for practical reasons, but I don't see how it does anything to clarify the foundational questions about quantum mechanics. Other than, perhaps, making it harder to ask those questions...
  • #132
Yes. My point is that a foundation that has to be modified when the building is mostly erected, wasn't a good foundation and doesn't really deserve that name. As understanding in physics grows, the foundations should be adapted as well.
  • #133
Actually it simplifies to ask appropriate questions and closes the door to others asked. For example, in the version I gave (which is what is used in quantum optics and quantum information theory), it says what happens independent of the measurement process, and in particular independent of any human observation of results. This already rules out consciousness as an agent, while the latter is implicitly present as a possibility in the traditional foundations.
One can still specialize to the case where the ##P_x## are rank one projectors, and gets the pure von Neumann case as a (very special) situation, sufficient to analyze nonlocality issues. But one then knows that one is in a very special situation.
This puts Bell-experiments into perspective as being a very special, hard to prepare situation. Normally, one hasn't this kind of nonlocality; otherwise doing physics would be impossible. Seeking out these extremes is like doing the same in the classical domain:
A. Neumaier said:
People very experienced in a particular area of real life can easily trick those who don't understand the corresponding matter well enough into believing that seemingly impossible things can happen. This is true in the classical domain, amply documented by magic tricks where really weird things happen, such as rabbits being pulled out of empty hats, etc..
The art of a magician consists in studying particular potentially weird aspects of Nature and presenting them in a context that emphasizes the weirdness. Part of the art consists of remaining silent about the true reasons why things work rationally, since then the weirdness is gone, and with it the entertainment value.
The same is true in the quantum domain. Apart from being technically very versed experimental physicists, people like Anton Zeilinger are quantum magicians entertaining the world with well-prepared quantum weirdness. And the general public loves it! Judging by its social impact, quantum weirdness will therefore never go away as long as highly reputed scientists are willing to play this role.
  • #134
It depends on what you're after. If you only want to say that, in practice, it's possible to ignore nonlocality and other quantum weirdness, I agree. That's why "shut up and calculate" works fine as an interpretation.
  • #135
Even the concepts are simpler since instead of requiring knowledge about eigenvalues and eigenvectors one only needs to assume that the reader can correctly interpret the relation ##\sum_x P_x^*P_x=1##, which is sufficient to get the POVM property, so it can be substituted for it.
If you only want to say that QM is nonlocal it is sufficient to point out that the Born rule specifies for a particle prepared at time ##t## in the local lab in a coherent state ##\psi(t)## a positive probability ##p_\Omega=\int_\Omega dx |\psi(x)|^2## that it is found instead at time ##t+\epsilon## in a given region ##\Omega## anywhere ##10^{100}## lightyears away in the universe. The probability is very small, admitted. But isn't it very weird and very nonlocal that it is positive and hence possible?
The fact that quantum mechanics works based on these nonlocal assumptions was known already in 1926. Understanding didn't increase by experiments that demonstrated the violation of Bell inequalities. Only some classical reasons how this could possibly be understood in simpler terms were eliminated.
  • #136
It seems to me that saying that QFT tells "what happens independent of the measurement process" is misleading, if not false. Yes, you can interpret QFT as giving statistical information about fields, and that doesn't seem to involve measurement. But to me that's no different than just picking position as a preferred basis in QM, and saying that QM gives us statistics about position. If you want to say that position has a privileged status in QM, you can do that--that's the Bohmian interpretation, basically, which is explicitly nonlolcal. If you don't give position a privileged status, then it seems to me that you have a measurement problem: quantum probabilities only make sense once a basis is chosen.
I really don't think you're right that QFT solves any of these problems.
  • #137
Yes, I think that that's a very important, often overlooked point. Many people act as if Bell's inequality tells us something new about QM. It really doesn't. Bell's inequality (and their violation) rule out a particular class of theories--the locally realistic theories. But we already knew that QM was not that type of theory. So the only impact of Bell's inequality was to dash the hopes of people like Einstein who thought that QM might be someday replaced by such a theory.
  • #138
To me, the comparison with magicians seems more like this:
We see a magician saw a lady in half and then put her back together, unharmed. There are three different reactions possible:
  1. Some people say: Wow, that guy really has magical powers.
  2. Some people (such as "The Amazing Randi") say: There is some trick involved---I want to figure out what it is.
  3. Other people say: Why are we focusing on such an extreme, unnatural case? In the vast majority of actual cases, when someone is sawed in half, they don't recover. Let's just worry about these typical cases.
  • #139
You took my statement out of context. Here I was arguing not about QFT but about the modern foundation of quantum mechanics described in post #128. It is a much more powerful formulation of the Copenhagen interpretation than the usual ones. (Though to save time I didn't make the density matrix version explicit, and that I assumed as Paris a finite-dimensional Hilbert space. For a completely specified set of postulates appropriate for modern quantum mechanics (fully compatible but in detail differing from post #128) see my Postulates for the formal core of quantum mechanics from my theoretical physics FAQ. If you want to discuss these, please do so in a separate thread.)
All this is purely about QM in its standard form - just making explicit what people in the literature actually do rather than basing it on published - out-of-date or poorly designed - postulates. My postulates say what happens whether or not something is measured, and tell you how you can verify it statistically by experiment if you are inclined to do so, have the means to prepare the corresponding experiments, and figured out how to extract the ##x## from the detector or its environment. The latter only requires standard qualitative reasoning that experimenters are familiar with.
Everything is in principle verifiable, without ever having to pick a preferred basis. In place of the preferred basis one has the ##P_x##, which is determined by the instrument in a completely rational fashion. Books and lecture notes on quantum information theory teach you how to determine experimentally the ##P_x## for some instrument if you don't know them, and how to find out the density matrix in which a sufficiently stationary source is prepared. All probabilities can be checked by calculating the frequencies of having measured various ##x## and dividing by the frequencies obtained when in place of the instruments one has only a detector that counts the number of systems arriving.
But this is not QFT. In QFT at finite times there is no particle picture, and only field expectations and correlation functions make operational sense. This leads to important differences; see posts #31 and #101.
  • #140
I just have had the pleasure to listen to a brillant colloquium talk by Zeilinger. He's far from behaving like a magician but very careful on the "no-nonsense side" if it comes to interpretation. His experiments over the years do not show any hint of "weirdness" but just verifies the predictions of standard quantum theory with high precision, including very successful Bell tests, double-slit/grating experiments with buckyballs demonstrating decoherence etc. etc.
  • #141
The postulates 1-6 in your FAQ are indeed standard QT, and I subscribe to them. I've only one question: Why is it sufficient to define the stat. op. as hermitean? I always thought it must be (essentially) self-adjoint.
I also don't think that you have to change anything concerning relativistic QFT. Of course, observables must be defined by (gauge-independent) observables in terms of the quantum fields, and indeed, a particle interpretation is valid only in a very specific limited sense of asymptotic free Fock states.
  • #142
Indeed, the practical implications of quantum mechanics may qualify as magical powers for the uninformed and for people from before 1950, say. People from that time would have viewed as science fiction what is now reality due to transistors, lasers, memory chips and other products of quantum engineering.
But you forgot the Magician's reaction, who says ''I have a sufficient understanding of Nature that I can prepare situations where Nature works predictably in ways that are regarded as magical by the less informed. Since I understand it, for me no magic is involved.''
This is the rational response. We don't need a metaphysical understanding how Nature achieves nonlocality. It is enough to understand Nature enough to utilize its powers. And we do.
  • #143
It's hard to distinguish between that case and case 3. Especially when the magician, when asked about the sawing the lady in half, changes the topic to those cases where saws work as expected.
  • #144
Well, my response is for magicians among themselves and their disciples. On stage the magician has to change topic, or he would soon lose his reputation...
  • #145
Of course they don't. No experiments do. Weirdness can only be in the interpretation of an experiment, not in the experiment itself.
If I see a flying elephant, there is nothing weird about that. But if I combine it with my expectations that elephants should not fly, then it becomes weird.
  • #146
It is self-evidently right for position. ##P(x) = |\langle x| \psi \rangle|^{2} = |\psi(x)|^{2}##, then the expectation value of x is ##\langle x \rangle = \int x P(x) dx ##. As long as specifying all moments and cumulants is the same as specifying the probability distribution, then the two forms of the Born rule are equivalent.
Hmmm, probably you are taking the "textbook" formulation too literally, as if the state assigned to the system is really the state assigned to the system. If you take the Copenhagen pure state assigned to a single system as just a convenient fiction, and that the only thing that is real in quantum mechanics is the probability distribution of outcomes, the differences between the final and initial versions are technical, not spiritual.
Also, Paris does have wave function collapse. It's the rule he calls state reduction.
  • #147
Well, as I said before, this argument can be generalized only to observables that are functions of positions alone. But how do you conclude something about the distribution of ##H=p^2/2m+V(x)##?
If one cannot take the foundational postulates literally, so that they need another interpretation, what good are they?
Do you want to suggest that one has to add to the interpretation the additional postulate that the state assigned to the system is not the state assigned to the system. It seems to me that this would solve the problem in a too trivial way since from X equals not X one can deduce arbitrary sense and nonsense.
This changes the Copenhagen interpretation into the ensemble interpretation.
Yes, and so has my version in post #128. This is why I call it a more powerful form of the CI.
  • #148
A. Neumaier said:
Well, as I said before, this argument can be generalized only to observables that are functions of positions alone. But how do you conclude something about the distribution of $H=p^2/2m+V(x)##?
Let me keep this as homework that I owe you :P
There is no difference between the Copenhagen and the Ensemble interpretation, when both are done correctly. A key point is that Copenhagen = Ensemble has the measurement problem.
  • #149
Yes, as stressed several times, roughly speaking the Kopenhagen flavor by Bohr can be described as "minimal interpretation + collaps and quantum-classical cut". The physics part is identical, and thus I prefer the minimal interpretation, because both collapse and the quantum-classical cut are very problematic (to say it mildly ;-)).
  • #150
Of course, we all know, how it is defined,
$$\langle E \rangle=\langle \psi|\hat{H} \langle \psi=\int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x} \psi^*(x) \left [-\frac{\Delta}{2m}+V(x) \right ] \psi(x).$$
This is unambiguously defined in the mathematical foundations and has nothing to do with any "interpretation weirdness".
  • · Replies 22 ·
  • · Replies 36 ·
  • · Replies 18 ·
  • · Replies 182 ·
16K
  • · Replies 26 ·
