V required so ions passing through the region don't devitate
The problem involves hydrogen ions moving through a region with combined electric and magnetic fields. The task is to determine the potential difference V required for the ions to pass through without deviation, given their speed and the characteristics of the fields present.
  • Participants discuss the conditions necessary for ions to remain undeflected in the presence of electric and magnetic fields. There are attempts to derive expressions and clarify the forces acting on the ions. Some participants question the validity of the provided answer for the kinetic energy of the ions.
The discussion is ongoing, with participants exploring various approaches to the problem. Some have suggested using symbolic representations rather than numerical values initially, while others are clarifying the roles of the electric and magnetic forces. There is no explicit consensus yet, but several productive lines of inquiry are being pursued.
Participants note potential confusion regarding the charge of the hydrogen ion and the purpose of the parallel plates in the setup. There are also discussions about the relevance of mass in the context of the forces acting on the ions.
moenste
Hydrogen ions moving at various speeds are directed at a region of combined electric and magnetic fields as shown in the diagram below. The electric field is between two parallel plates 10 mm apart with a potential difference V across them, while the magnetic field of flux density 0.1 T is at right angles to the electric field.
(a) Calculate the value of V required so that ions of speed 100 m s-1 pass through the region of the two fields without being deviated.
(b) What is the kinetic energy per ion as they leave the combined fields?
(1 u = 1.67 * 10-27 kg.)
Answers: (a) 0.1 V, (b) 8.4 * 10-24 J.
2. The attempt at a solution
(a) Can't get it right. I use 0.5 m v2 = e V, where we don't know the mass m. I then tried to use F = B e v = 0.1 * 1.6 * 10-19 * 100 = 1.6 * 10-18 N and then F = m g so m = F / g = 1.6 * 10-18 / 10 = 1.6 * 10-19 kg -- not correct.
I also used B e v = m v2 / r so m = B e r / v = 0.1 * 1.6 * 10-19 * 0.01 / 100 = 1.6 * 10-24 kg. Also not correct.
I even thought that since we have hydrogen then its relative atomic mass is 1.008 and so 1.008 * 1.67 * 10-27 = 1.68 * 10-27 kg, also not correct.
If we plug in 0.1 V (which we need to find) into the first formula we'll get m = 3.2 * 10-24 kg. But I've got no idea how to find it.
You're plugging in numbers way too soon. Use symbols to start with.
What condition must hold if the ions are not going to be deflected? Can you write an expression for that?
Also, you may want to check that the given answer for part (b) is not a typo. Something on the order of 10-4 Joules for a single hydrogen ion would be mighty impressive indeed.
Maybe you are talking about "An electron moving with velocity v at right angles to a magnetic field of flux density B experiences a force F, which is given by equation F = B e v."? And since the electron experiences this force, in order to move in the same direction it should have F to move + additional F to overcome the magnetic field force. Am I going in the right direction?
Ah, sorry, it's -24, not -4!
That's the idea. Only in this case the electron is replaced with a hydrogen ion. What's the charge on a hydrogen ion? And what force is it that's providing the "additional F"? What's an expression for that force?
:smile:
Chage on the ion is 1.
Maybe it's F = 2 B e v?
1 what?
Are there two magnetic fields? What is the purpose of the parallel plates?
gneill said:
1 what?
Don't know. It only says something like this. Couldn't find a clear number. Some +1 or 1+ everywhere.
Maybe I need to have: m = 2 B e r / v = 2 * 1.6 * 10-24 = 3.2 * 10-24 kg. Double it, since we have two plates.
What do you think is the purpose of the plates? What forces are acting on the ion when it gets in between the plates?
What is the charge on an electron? What is the charge on a proton?
I'd say they remind me the Hall effect -- two plates that create a magnetic field that makes the particle deviate from its path. Don't know whether this applies here.
Hint: The mass of the particle is irrelevant until you need to talk about kinetic energy. Only magnetic and electric forces are of interest right now.
Plates do not create a magnetic field. What kind of field do they produce when they are supplied with a potential difference?
You are close.
Magnetic field will tend to deviate the ion. But if the ion is not supposed to deviate along its way, what will stop it from deviating?
It's the elementary charge 1.6 * 10-19 C.
It says on Wikipedia also 1.6 * 10-19 C...
moenste said:
It's the elementary charge 1.6 * 10-19 C.It says on Wikipedia also 1.6 * 10-19 C...
Right. What's the difference between the two?
You'll soon notice that this value is also not necessary for calculation of V.
An "electric field" as mentioned in the problem?
cnh1995 said:
You are close.
A larger inner force? Like if we have a car which is going on an inclined road and has friction to be overcomed, we need more force.
Yes.
And who will provide this "inner force" in this problem? Also, should it be larger than the deviating force?
cnh1995 said:
And who will provide this "inner force"? Also, should it be larger than the deviating force?
Hydrogen ions? The plates only create an electric field that makes the ions deviate.
Well, they are moving with FInitial, then they are experiencing a FE. Field force, so if we want them to continue in the same direction we need FInitial + F = FE. Field.
The ion is not moving with an initial force. It has an initial velocity of 100m/s. To maintain that velocity throughout along its way, the ion must experience zero net force(Newton's 1rst law). How is this achieved when the ion is in between the plates?
You seem to be multiplying the number forces involved without justification. Now you have FInitial, F, and FE. Field without pinning down what they might be or how they are calculated.
There are only two forces operating: The magnetic field and the electric field. You should be able to write expressions for both as they act on the moving particle.
0.5 m v2 = e V?
Left is before the field and right is after entering the field?
moenste said:
0.5 m v2 = e V?
No. The ion enters the plate region with velocity 100m/s. Which forces are acting on it the moment it enters the region? Forget about the situation before the ion enters the plate region. It is not of any use or significance here.
F = m g and F = m a?
Again, mass is not in the picture here because gravity doesn't affect subatomic particles. You yourself have recognized the two forces earlier, but in two separate posts.
F = B e v?
moenste said:
F = B e v?
And??
cnh1995 said:
And??
B e v = m v2 / r? But mass is not in the picture as you said.
No. Read #19 again. Basically, why does the question ask for voltage? Which force does that suggest?
I'm not sure why you seem to being denying the existence of the electric field between the plates :oldconfused: You seem to be going out of your way to avoid mentioning it. Perhaps you haven't been introduced to electric fields between parallel plates?
The purpose of the plates with a potential difference V is to establish an electric field between them. Now. What is the force on a charge in a uniform electric field E?
9K
