Angular Acceleration of a Rod in an Uneven String Setup
The discussion revolves around the angular acceleration of a rod in a setup with uneven string lengths, where the angles of the strings are specified. Participants are analyzing the forces and torques acting on the rod after one of the strings is cut, and they are attempting to derive equations of motion based on these conditions.
  • Mixed
  • Participants discuss the equations of motion derived from force and torque analysis, questioning the correctness of the constraint equations used. Some express uncertainty about the implications of the rod's movement after the string is cut.
There is an ongoing examination of the equations presented, with some participants agreeing with the original poster's results while others reference an official answer key that differs. The conversation includes a consideration of modified setups and the implications of different constraints on the motion of the rod.
Participants are working within the constraints of a homework problem, which may limit the information available for discussion. There is a focus on ensuring the accuracy of the derived equations and understanding the physical behavior of the system post-string cut.
Vibhor
Note : In the above setup the string lengths are unequal and the left angle is 30° and right angle is 60° .
[/B]
Just after the string is cut , writing force eq. for rod in vertical direction .
##Mg - Tcos60° = Ma_y ## (1)
Writing force eq in horizontal direction
##Tsin60° = Ma_x## (2)
Writing torque eq about the CM of the rod ,
##Tcos 60°\frac{L}{2} = \frac{ML^2}{12} \alpha ## (3)Writing constraint eq. for the left end point of the rod where string is attached ,the component of acceleration of left end along the string length should be zero .
##a_ycos60° - \frac{αL}{2}cos60° - a_xcos30°= 0 ## (4)Solving the above four eqs .give ##T= \frac{2}{7}Mg##
and ##\alpha = \frac{6g}{7L}##
Could someone check my work ?
It all looks ok to me.
According to official answer key , T=Mg/2 and α = 3g/2L :oldeyes: .
Do you mind rechecking the constraint equation ?
Is there some sign error ?
Now consider a modified setup .
The same four equations in this case would be
##Mg - Tsin2\theta = Ma_y##
##Tcos 2\theta = Ma_x ##
##Tsin \theta \frac{L}{2} = \frac{ML^2}{12}\alpha##
##a_y cos(90°-2\theta) - \frac{\alpha L}{2}cos(90°- \theta) - a_x cos2\theta = 0 ##
Please check the above equations .
I rechecked my calculations but the result is same as the one in OP .
The answer key doesn't have too many mistakes .
I also agree with the answer in the OP.
One way to get their answer is to replace the correct constraint equation with the incorrect equation ##a_y = \alpha L/2## (as though the rod is instantaneously rotating about a fixed left end).
Or in the case when both the strings are vertical .
Do you think my equations for the set up in post 4 are correct ?
Yes, a vertical string would give a constraint of ##a_y = \alpha L/2##. But then, I think you would get T = Mg/4.
Yes, they look correct to me.
Yes .
Thank you very much .
Thanks @haruspex
Please see the attached image .
Just after the right string is cut , the net acceleration of the CM of the rod is vertically downwards .Hence rod must move such that CM falls straight down.The left end must also fall straight down .
But net acceleration of the left end point will be towards left ,which means the next instant after right string snaps , it moves towards left .
Aren't the movement of CM and left end contradicting each other .
I am sure I am messing somewhere .
Why? There will be an angular acceleration.
Right . So the next instant , rod moves such that CM moves straight down and the left end moves leftwards ?
Yes.
  • · Replies 97 ·
  • · Replies 25 ·
