PainterGuy
- 938
- 73
- TL;DR
- I have a question about clock synchronization which is directly related to the simultaneity. One could say that clock synchronization is the main pillar of special relativity because this is the 'convention' which makes the speed of light constant for all observers, and moreover it is the convention which is used to define an inertial frame of reference in the special relativity.
Hi,
There are three clocks - Clock A, Clock B, and Clock C. The distance, D, between each clock is 6 light-second. The clocks are situated in a frame of reference which is moving toward the right at speed of 0.5c where 'c' is taken to be 300000000 m/s. Please look here: https://imagizer.imageshack.com/img921/4197/EaNwTf.jpg
The clocks are to be synchronized according to Einstein-Poincare scheme of synchronization. Clock A is situated in the middle of other two clocks. Clock A sends pulses to both other clocks at 12:00:00
For Clock B, the time of round trip is:
from A to B:
(c+0.5c)t=6 light-second
1.5ct=6 light-second
t=4 seconds
from B to A:
t=12 seconds
Therefore, total round trip time is: 16 seconds. It is assumed that one way trip time taken by the pulse is 16/2=8 seconds.
For Clock C, the time of round trip is:
from A to C:
t=12 seconds
from C to A:
t=4 seconds
Total round trip time is 16 seconds and therefore one way trip time is 16/2=8 seconds.
If the clocks are synchronized then Clock B should have shown 12:00:00 plus 00:00:08, i.e. 12:00:08, on the arrival of pulse. Similarly, Clock C should have also shown 12:00:08 when it received the pulse if it was synchronized with Clock A.
Am I following the synchronization procedure correctly? Could you please help me with it?
from A to B:
t=4 seconds
from B to A:
t=12 seconds
from A to C:
t=12 seconds
from C to A:
t=4 seconds
Let me elaborate on it below.
