B Here's a Statistics problem for game of Polo (or Hockey if you like)
  • B
  • Thread starter Thread starter wirefree
    Sports Statistics
A hypothesis suggests that a strongly-knit team wins more often than a less-knit one, measured by the standard deviation (SD) of player handicaps. However, findings indicate that teams with a higher SD, representing less-knit compositions, tend to win more frequently. For example, a team with handicaps of -2, 0, 2, and 4 (SD = 2.2) outperforms a more balanced team with handicaps of 2, 2, 3, and 3 (SD = 0.5). This suggests that the presence of a standout player may be a critical factor in a team's success. Further analysis of outliers in winning teams could provide additional insights into success factors.
wirefree
TL;DR
Trying to find the characteristics of the winning team in terms of stan. devi. of their team's abilities.
Namaste & G'day
Postulate: A strongly-knit team wins on average over a less knit one
Fundamentals:
- Two teams face off with 4 players each
- A polo team consists of players that each have assigned to them a measure of their ability (called a "Handicap" - 10 is highest, -2 lowest)
I attempted to measure close-knitness of a team in terms of standard deviation (SD) of handicaps of the players.
Failure: It turns out that, more often than, a team with a higher SD wins. In my language, that means a less knit team. So, it turns out that a team with handicaps -2,0,2,4 (one really good player, one very poor player; (SD = 2.2) wins more often than a team with average handicaps, say, 2,2,3,3 (SD = 0.5)
I need your help.
How would you go about determining success factors?
What other combination of SD and/or handicaps would you recommend?
Some other combinations me, a statistics novice, tried without success:
- SD*(max of team's handicaps - min of team's handicaps)
- SD/(max of team's handicaps - min of team's handicaps)
- SD*(max of team's handicaps)
- SD/(max of team's handicaps)
Regards
wirefree
So it seems as though your hypothesis may be wrong. Perhaps the success of a team tends to depend on having a superstar player whose handicap increases the SD.
Thanks for your thoughts. I really appreciate it.
You can look to see if outliers are present in the winning teams.
Hello, I'm joining this forum to ask two questions which have nagged me for some time. They both are presumed obvious, yet don't make sense to me. Nobody will explain their positions, which is...uh...aka science. I also have a thread for the other question. But this one involves probability, known as the Monty Hall Problem. Please see any number of YouTube videos on this for an explanation, I'll leave it to them to explain it. I question the predicate of all those who answer this...
There is a nice little variation of the problem. The host says, after you have chosen the door, that you can change your guess, but to sweeten the deal, he says you can choose the two other doors, if you wish. This proposition is a no brainer, however before you are quick enough to accept it, the host opens one of the two doors and it is empty. In this version you really want to change your pick, but at the same time ask yourself is the host impartial and does that change anything. The host...
