Chain falling out of a horizontal tube onto a table
  • Thread starter Thread starter NTesla
The discussion revolves around the mechanics of a chain falling out of a horizontal tube onto a table, specifically addressing the calculation of the speed of the chain's end as it exits the tube. Initial and final mechanical energy equations are presented, but discrepancies arise between the calculated speed and the book's answer, prompting a deeper examination of energy conservation principles. Participants highlight the complexities of tension in the chain and the implications of inelastic collisions with the table, suggesting that mechanical energy is lost during the process. The conversation also touches on the need for careful consideration of boundary conditions and the assumptions made in the problem statement. Ultimately, the discussion emphasizes the importance of understanding the dynamics of falling chains and the limitations of energy-based approaches in such scenarios.
NTesla
The question is from Irodov Q 1.184. See the Screenshot.
I'm trying to solve it using energy conservation. My thinking is that since all the surfaces are frictionless and only conservative gravitational force is acting, therefore, ME must be conserved.
My attempt:
Initial total M.E = PE of hanging part + PE of part of chain in the tube. I've considered the table as to be at zero of PE.
PE of hanging part = ##\frac{1}{2} \frac{m}{l}gh^{2}##.
PE of part in the tube = ##\frac{m}{l}(l - h)gh##.
Final ME = ##\frac{1}{2}\frac{m}{l}gh^{2}## + ##\frac{1}{2}\frac{m}{l}hv^{2}##.
Since Initial ME = Final ME. Therefore, ##\frac{1}{2}\frac{m}{l}hv^{2}## = ##\frac{m}{l}(l-h)gh##. Solving this gives: ## v = \sqrt{2g(l-h)}##. But the answer in the book is: ##v = \sqrt{2ghln(\frac{l}{h})}##.
NTesla said:
Homework Statement: The question is from Irodov Q 1.184. See the Screenshot.
@NTesla, the last part of the question on the screenshot is missing. So here’s what (I believe) it should say:
"... At a certain moment, end-A of the chain is released. What is the speed of end-A when it reaches the right-hand end of the tube?"
Are you sure about that? Suppose the whole chain, not just part of the chain, had reached the floor and come to rest. What would the final ME be? If it is different to the initial ME, how do you account for this difference?
Yes, thanks. Edited. The missing screenshot has been added in the original post.
Yes, that's a valid point.
  • Agree
Likes Steve4Physics
There are a number of conundrums that deal with the unexpected behavior of falling ropes and chains. It seems clear that you are not intended to worry about the fine details involved with those.
The intent is that you pretend that the portion of the chain that reaches the table is quietly removed from existence as it gets there.
If a falling link strikes the table at an angle (perhaps nudged to an angle by the portion of the chain that had already fallen) then the strike will impart spin. That spin will pull down on the remainder of the falling chain. Almost paradoxically, the upward force from the table below has the net effect of a downward force on the falling chain.
https://en.wikipedia.org/wiki/Chain_fountain
When writing "ln(x)” in LaTeX, you can make it clearer with "\ln": ##\ln(x)## v. ##ln(x)##. This avoids confusion when ##l## or ##n## is also a variable.
All the equations that I had written have been deleted by the moderator. I don't understand why. Is that just because ##\ln## was not written as it should have been ?
Do you mean the equations from your Post #1? I can see them. Here's a copy, though LaTeX rendering may be a problem:
NTesla said:
My attempt:
And here is a screenshot.
In principle one can introduce a tension force along the chain and write down the 2nd Newton law for each ##\Delta m##. But where should one take boundary conditions for the tension force at the end of the tube?
I do not understand. There is no discontinuity in tension at the end of the tube where the chain turns downward. The obvious boundary conditions are at the left end of the chain in the tube (tension zero there) and at the bottom where the chain strikes the table (tension zero there as well).
If one considers the gradient in tension across each ##\Delta m## then the gradient is constant within the tube and is also constant within the falling segment of chain. The gradient changes across the [negligibly small] curve at the mouth of the tunnel.
why?
wrobel said:
why?
The tube is smooth (frictionless). The mouth of the tube acts like an ideal pulley. The direction of the tension force changes there. But the magnitude of the tension does not.
In exercises as a rule pulleys are considered with massless strings.
This is a hypothesis it does not follow from equations of motion. In my opinion this hypothesis is not evident and thus it must be fixed in the statement of the problem.
Whether it’s a track over a smooth shoulder or a massless pulley is clearly independent of whether the problem concerns a massless string or a massive one.
If there is a step change in the tension anywhere then there is a string element of infinitesimal mass subject to a non-infinitesimal net force in the tangential direction, no? Taking the string to be inextensible and following a fixed path, the magnitude of its tangential acceleration is the same everywhere.
then it must be incompressible as well. Is the chain under consideration incompressible? Why?
If it is incompressible it stops when reaching the point B :)
Here's how I'm trying to solve it, using Newton's 2nd law.
I'm considering the whole chain as the system. Let at any instant of time, t, the horizontal part of the chain is x distance from the left end. ##v## is the velocity of the chain at the instant t. ##\lambda## is the mass per unit length.
## \Delta\vec{P} = \vec{P_{f}} - \vec{P_{i}}##
##\vec{P_{i}} = \lambda (l - x - h)v\hat{i} - \lambda hv\hat{j}##
##\vec{P_{f}} = \lambda (l - (x + \Delta{x}) - h)(v + \Delta{v}) \hat{i} - \lambda h(v + \Delta{v}) \hat{j}##
This gives in the ##\hat{i}## direction: ## \Delta\vec{P} = \lambda\left ( (l - x - h)\Delta{v} - \Delta{x}v \right )\hat{i} ##. (ignoring ##\Delta{x}\Delta{v}##).
Now, in the ##\hat{i}## direction, the force is due to the weight of the hanging part of the chain, which is constant, as long as x ranges from 0 to ##(l-h)## and that force is = ##\lambda hg##.
From here, the differential equation in the limit ##\Delta{t} ## tends to 0, gives: $$(l - x - h)\frac{dv}{dt} - v^{2} = hg$$.
But solving this differential equation is not giving the right answer. I'm dont know where I'm going wrong.
my version is
$$\ddot x=-\frac{gh}{x+h},$$
where ##x## is a length of the horizontal tail
wrobel said:
....If ##x_0## is an initial length of the horizontal tail then
$$v=\sqrt{2gh\ln(1+x_0/h)}$$
is that the answer?
No. That's not the answer.
I've posted the correct answer in the original post.
look carefully :) My answer is the same as one in the original post
In your equation, you wrote, x is length of horizontal tail, that led me to think that by "tail" you meant the distance moved by the left end of the horizontal part of the chain. But now, I understand that by tail you wanted to mean length of the horizontal part of the chain. It would have been prudent to use the word "chain" instead of the word "tail" :) .
However, I still don't understand why my equations written in post#17 do not work.
By reverse engineering the correct equation, I've reached a few conclusion: The ##v^{2}## term should not be there in the last equation in post#17. Also, the force on the horizontal part of the chain is not = ##\lambda hg##, but is = ##\lambda h(g - \frac{dv}{dt})##. But for eliminating the ##v^{2}## term in the differential equation, the term ##\Delta {x}v\hat{i}## must be added in the ##\vec{P_{f}}## that I've written. But I don't understand on what grounds should that be written in ##\vec{P_{f}}##.
Chains buckle under compression. Like cables, ropes, cords, strings and threads.
The intent of the problem is clearly that the chain crumples into the table below without passing the resulting contact force back up the chain, either as compression or as tension.
It is clear that the chain is under tension throughout its moving length, from point B, up through the mouth of the tube and left through the tube all the way to the chain's tail end in the tube.
NTesla:
Consider the vertical part of the chain. Let ##N(x)## be a tension force that acts in the section that lies at the height ##x##. For an infinitesimal chain's interval of length ##ds## write down the 2nd Newton:
$$\rho ds a=-g\rho ds+N(x+ds)-N(x)=-g\rho ds+N'(x)ds+o(ds),$$ here ##\rho## is a density of the chain; ##a## is an acceleration.
Thus we have
$$\rho a=N'(x)-g\rho.$$
Take the integral ##\int_0^h dx## from the both sides of this equality
$$\rho a h=N(h)-N(0)-g\rho h,\quad N(0)=0.$$
Do the same for the horizontal part of the chain.
wrobel said:
NTesla:
Thus we have
I'm trying to understand your solution. Could you kindly tell me what does the last term ##o(ds)## mean, and where did that come from. I understood till the term ##N'(x)ds##.
Secondly, by simplifying the equation: $$\rho a=N'(x)-g\rho.$$, we get:
$$\rho vdv = dN - g\rho dx$$. LHS of this can be integrated for some values of v, but you've mentioned to use ##\int_0^h dx## on both sides of this equation. This part I dont understand. Kindly explain.
This is a re-write of my original post – of which I am ashamed.
Mechanical energy is lost, because of the inelastic collision between the chain and the floor. This makes it unlikely that methods based on energy will be of any use. This prediction is confirmed by the form of the answer.
Instead we apply ##F=ma## to the moving part of the chain... Suppose that when length ##s## has hit the deck, the rest of the chain is moving at speed ##w##. Writing ##\mu=\frac m l##, the mass per unit length of chain, we have
$$\mu h g = \mu (l-s) \frac{dw}{dt}$$
[Strictly the part of the chain in still in the tube and the vertical parts ought to be treated separately, as they are accelerating in different directions, but the above equation is a valid short-cut.]
We now use some mathematical trickery to re-express ##\frac{dw}{dt}##...
$$\frac{dw}{dt} = \frac{ds}{dt} \frac {dw}{ds} = w \frac {dw}{ds} = \tfrac 1 2 \frac{d{w^2}}{ds}$$
So our ##F=ma## equation becomes
$$\mu h g = \mu (l-s) \times \tfrac 1 2 \frac{d{w^2}}{ds}$$
Separating variables, integrating and Imposing the initial condition ##w=0## when ##s=0##, and the 'final' condition, ##w=v## when ##s=l-h##, we obtain the answer in your book.
Traps I fell into earlier
(1) I thought for a while that the final speed when the chain hits the deck and forms a stationary heap (of negligible height) would be the same as if when the lower part of the chain meets the deck it is guided round a smooth quarter-circle ramp in a vertical plane, so it doesn't lose KE but carries on moving, but across the deck. I was put right by jbriggs44 – thank you.
(2) Abandoning (1), I noted that the rate of loss of downward momentum of the chain when length ##s## has hit the deck and stopped is ##\mu w^2##. This is therefore the upward force on the falling chain from the deck. I foolishly then included ##-\mu v^2## as a term on the left hand side of the ##F=ma## equation. But the force from the deck is 'used' to change the momentum of the chain as it hits the deck, and isn't given to the rest of the chain.
Philip Wood said:
Now suppose that when the lower part of the chain meets the deck it is guided round a smooth quarter-circle ramp in a vertical plane, so it doesn't lose KE but carries on moving, but across the deck.
I had considered offering this as a supposed equivalence. But it is not quite right.
The portions of the chain that are falling through the air or being pulled from the tube share the same acceleration. In magnitude at least. The portion of the chain that is sliding across the table will not be accelerating. This leads to a problem. The chain must buckle at point B due to the mismatched accelerations.
If the chain is going to buckle at point B anyway, we should go ahead and let it just pile up on the table.
"The portion of the chain that is sliding across the table will not be accelerating." Why can't it have the same |acceleration| as the rest of the chain? I should have extended the ramp in a straight line across the deck. But I now agree that I was wrong to argue that the end-speed found for the ramp set-up will also be the speed at which the chain hits the deck inelastically (and forms a stationary heap – of negligible height!).
Philip Wood said:
Have you now appreciated that there WOULD usually be a loss of mechanical energy, because of the inelastic collision between the chain and the floor? You mustn't equate the total loss of gravitational PE, ##\frac {m}{l} g(l-h)##, to the KE of the length, ##h##, still in motion at the end-time.
Now suppose that when the lower part of the chain meets the deck it is guided round a smooth quarter-circle ramp in a vertical plane, so it doesn't lose KE but carries on moving, but across the deck. All parts of the chain will be moving at the same speed. In that case the speed at the end time is found by equating the loss in gravity PE to the KE of the whole length, ##l##, of chain.
Now here's the subtle bit (well I didn't spot it for a while)... The end-speed found for the ramp set-up will also be the speed at which the chain hits the deck inelastically (and forms a stationary heap – of negligible height!). This is because the upward force on the vertical part of the chain will be the same in both cases because vertical momentum is destroyed at the same rate).
How do I make the latex delimiters spring into action?
Appreciate your input. However, I've already understood that mechanical energy will not be conserved in the given situation. That's why I've now tried to solve the question using Newton's 2nd law. Kindly see the post#17 and 22 above, wherein I've written the equations. I don't understand why the equations that I've written in post#17 don't work. If you have insights regarding that, it will be very much welcome.
Philip Wood said:
"The portion of the chain that is sliding across the table will not be accelerating." Why can't it have the same |acceleration| as the rest of the chain? Perhaps I should have extended the ramp in a straight line across the deck.
Since the problem statement does not specify what happens to the chain on reaching the table we have to make a reasonable guess about the intent.
Judging by the diagram, there is no ramp that would redirect it across the table.
A real chain would pile up haphazardly, coming to rest. It would also stack up, reducing the drop height, but we've not enough information about it to process that and it would be unreasonably complicated.
As noted by @jbriggs444 in post #5, chains (and perhaps ropes of any stiffness?) can have a significant effect from the rotation of the segments stacking. I do not know whether that depends on the segment length, or, if it does, whether the effect disappears in the limit as that length tends to zero. That would be an interesting study, but still likely way beyond the intent of the question.
This leaves us with the model that the chain annihilates on contact with the table.
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 19 ·
