cianfa72
- 2,958
- 308
- TL;DR
- About the definition of axial angular momentum and its calculation using moment of inertia tensor
Hi, I'd ask for clarification about some topics on angular momentum calculation.
Consider a system of particles moving w.r.t. a given inertial frame ##\mathcal A##. Picked a point ##P## in ##\mathcal A## one defines the angular momentum vector ##\vec L## w.r.t. the reference point/pole P.
Furthermore one defines the axial angular momentum ##L_a## as the component along ##a## of the system's angular momentum ##\vec L## calculated w.r.t. a pole ##P## on the axis ##a##. Such a notion is well defined since it doesn't depend on the particular pole ##P## chosen on the ##a## axis to do the calculation.
Next the notion of system's moment of inertia tensor ##I## is introduced that allows to calculate the axial angular momentum ##L_a## for the system supposed to rotate "as a rigid body" about any given ##a## axis with angular velocity ##\omega##.
