gen x
- 86
- 3
Both the main electrical cable (three-phase, line to neutral=230V, line to line =400V, 50Hz) and the water supply line(ppr pipe) are underground, below the earth in the garden, located next to each other, the main electrical power has damaged insulation, bare live line is exposed to a water leak from a broken main potable water line. So fault contact happen before RCD.
Could this situation be dangerous, especially if a person is showering at the same time? I am trying to understand whether this could create a shock risk to occupants and how effective will be RCD in house(downstream from fault contact) or breakers in upstream transformer(power source) would be in such a scenario.
House has classical wiring system,so every electrical device has ground wire connect to metal housing, water heater in bathroom as well.
