Confusion about one of Maxwell's equations
  • Context: High School
  • Thread starter Thread starter Ax_xiom
11 replies · 2K views
Ax_xiom
TL;DR
Why does a rotating wire in a magnetic field only cause a current within that wire
So Faraday's Law of induction states this: $$ \nabla \times E = - \frac {\partial B} {\partial t} $$
Or if we write it in it's integral form: $$ \int E \cdot dl = - \frac {d \Phi_B} {dt} $$ which (to my understanding) means that the magnitude of the EMF around a coil of wire will be equal to the magnitude of the change flux through that wire. I get confused in some cases as when we have a generator like this:
Nowhere in the region between the 2 magnets is the field actually changing, so (with my limited understanding) no electric field should be generated.
If we make the coil stationary and rotate the magnet instead, everywhere in between the magnets is experiencing a change in flux, so everywhere should have an electric field, but one is only generated within the wire
So what is wrong with my understanding?
Ax_xiom said:
TL;DR: Why does a rotating wire in a magnetic field only cause a current within that wire
Yes, loop integral of electric field is generated with no regard to the wire.
Free electrons in the conductor wire on the loop are required for generation of the force which are charge times electric field.
That is correct. The EMF in the wire is not due to an E field. The EMF in the wire is due to the Lorentz force on the charges in the wire.
Reply
So in most cases, is the induction from a coil in a magnetic field not due to Faraday's Law of Induction?
So the electric field is generated everywhere, but a current is only generated within the wire due to it having free electrons?
Yes. No charge, no current.
I wouldn’t say “most cases”. In very many cases you do have changing magnetic fields.
But not in the case of a coil rotating in a magnetic field (if so, are the underlying physics causing a current to be generated in a rotating wire in a magnetic field different to the physics of the same thing happening in a wire surrounded by a rotating magnet? If so, why?)
Correct.
It can be slightly different because in one case an accelerometer will detect that one is accelerating and in the other case the other will be accelerating. Rotation is non inertial.
To understand how an experiment or device works you need to consider Maxwell’s equations in a reference frame that is inertial, meaning it is not itself accelerating or spinning.
This is about the amount of magnetic flux going through the open loop of the rotating wire. That is changing as the wire rotates. With the wire loop oriented as shown in the diagram, no flux passes through it. When the wire loop rotates, that changes to a maximum flux through the loop when it is oriented vertically.
Reply
The question of whether the Maxwell–Faraday equation plays a role—that is, whether the electric field has a non-conservative circulation—may depend on the choice of reference frame.
To avoid issues related to rotation, let us consider a rectangular conducting loop moving at constant velocity ## \mathbf{v} = v\,\mathbf{e}_x ## in a non-uniform magnetic field, for example: ## \mathbf{B} = k\,x\,\mathbf{e}_z.##
There is indeed an induced current in the loop because the magnetic flux through it varies with time. To explain this induced current, one invokes the magnetic force acting on the charge carriers, which is not the same on the two sides of the loop parallel to ##Oy##. The Maxwell–Faraday equation plays no role here. This is a case of “Lorentz induction”: a circuit moving in a steady magnetic field. In this way, one has constructed a linear electric generator that converts mechanical energy into electrical energy.
However, one may also consider the reference frame ##(O, x', y, z)## attached to the loop. In this frame, the loop is at rest, and the magnetic field has become time-dependent.
In the non-relativistic limit, the transformation laws for the fields are simple:
\mathbf{E}' = \mathbf{E} + \mathbf{v} \times \mathbf{B},
\qquad
\mathbf{B}' = \mathbf{B}.
The term :
\mathbf{E}_i = \mathbf{v} \times \mathbf{B}
is now a genuine electric field. Since ##x' = x - vt##, this field can be written as :
\mathbf{E}_i(x',t) = v\,\mathbf{e}_x \times k(x' + vt)\,\mathbf{e}_z = -k v (x' + vt)\,\mathbf{e}_y.
This field indeed has a non-conservative circulation:
\nabla \times \mathbf{E}_i = -k v\,\mathbf{e}_z = -\frac{\partial \mathbf{B}'}{\partial t'}.
It is this non-conservative electric field that now explains the appearance of the current in the loop.
Thus, simply by changing the reference frame, one sees that the Faraday law is effectively at work in this particular case.
Yes.
But ##\Phi_B = \int \int_\Sigma {\vec B \cdot d\vec S}## changes over time, because the angle between the magnetic field and the normal to the rotating surface changes over time.
##\Phi_B (t) = SB \cos {(\omega t + \alpha})##, where ##S## is the area of the loop.
##EMF = - {d\Phi_B \over dt} = SB\omega \sin {(\omega t + \alpha)}##
Source:
https://en.wikipedia.org/wiki/Maxwell's_equations#Integral_equations
Reply
In the reference frame attached to the magnets, the electric field has a conservative circulation, and therefore:
\oint \mathbf{E} \cdot d\mathbf{l} = 0.
There is indeed an electric field associated with the surface charges distributed along the conductor. However, it cannot sustain a current over a closed path, since it does not provide energy over a complete loop.
In this reference frame, it is the magnetic force that drives the current. One then has:
\oint (\mathbf{v} \times \mathbf{B}) \cdot d\mathbf{l} = -\frac{d\Phi}{dt}.
Reply
