Torques: Find Load on Piers Supporting 700N Girder
  • Thread starter Thread starter Aidan123
    Torques
To determine the load on the piers supporting a 700N girder, the problem involves calculating the forces acting on the girder based on its weight and the distances from the supports. The girder is 3.0m long, with supports located 30cm and 60cm from each end. The total weight of the girder must be balanced by the reactions at the piers, requiring the application of torque equilibrium principles. The discussion emphasizes the importance of showing work and explaining difficulties in solving the problem. Clear calculations and a structured approach are essential for finding the load carried by each pier.
Aidan123
A uniform girder weighing 700N is 3.0m long. It is placed horizontally on top of two narrow piers which is support it at points 30cm and 60cm respectively from its ends. Find the load carried by each pier.
Please post homework questions, and homework style questions in the appropriate homework subforum. Be sure to show your work and explain exactly where you are getting stuck.
Nice description.
So how are you attempting this problem?
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
