General Enginnering Problem Dealing with Voltage Supply
The discussion centers on issues with a DC voltage supply connected to a PIC board, where the voltage drops to 4.3V and current cuts off when using a 5V supply instead of the recommended 9V from the AC adapter. Participants suggest that the board may require 9V for proper operation due to internal regulators. They also caution that some power supplies may provide unfiltered DC, which could lead to voltage drops under load. Recommendations include checking the power supply's specifications and ensuring all connections are secure. If problems persist, consulting an electrical engineer or the manufacturer is advised for further troubleshooting.
McAfee
Hello,
So I'm facing some difficulties. I'm using a DC voltage supply and connecting it to a PIC Board. The AC adapter that comes with the board outputs 9V DC. To be safe I'm just using 5V from the DC voltage supply. When I connect it to the board the reading from the voltage supply drops to 4.3 volts and the current cutoffs too. Does this means that there is a short circuit with the board?
Thanks
First, why don't you want to use the AC adapter provided? If the adapter works, why lower the voltage?
It could well be there are regulator inside the board to get 5V and it needs 9V to do that. Current drops off might means that you don't have enough voltage to even turn on the circuit and not drawing current. You don't have enough info for people to judge. But the most important question is why do you want to change something that is designed to work with and work?
well you'd need to have an idea what is capacity of the supply, and what is demanded by the board. Capacity of supply will be written on it.
Be aware that some power supplies, especially those meant for charging batteries, provide unfiltered DC and will drop their voltage when loaded. Also they'd be not good for the electronice on your board.
To see if you have one of those, connect it(without the board) to your voltmater and select AC. If you read more than a couple tenths of a volt it is poorly filtered(if at all) so you probably need a different supply.
To verify, select meter to DC and note reading, then unplug supply. If voltage drops immediately it is unfiltered, if it takes a second or two to bleed down then it IS filtered.
So study both your supply and the manual that came with yuor board.
Ok Thanks guys. I'm going to try this in the lab room tomorrow and will reply with my results. Once again, Thanks.
for reaching out about your issue with the voltage supply and PIC board. It sounds like you may be experiencing a short circuit or some other issue with the board that is causing the voltage to drop and the current to cutoff. I would recommend checking all of your connections and ensuring that there are no loose or damaged components on the board. It is also possible that the board itself may be faulty and may need to be replaced. If the issue persists, I would suggest consulting with an electrical engineer or contacting the manufacturer for further assistance in troubleshooting the problem.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
