Higgs or Einstein: who describes mass/inertia comprehensively?
  • Thread starter Thread starter danR
    Einstein Higgs
The discussion centers on the distinction between the Higgs mechanism and Einstein's theory of relativity in explaining mass and inertia. While the Higgs field contributes to the rest mass of certain particles, it does not account for all mass, particularly that of protons, which is largely due to internal energy from gluons and quarks. Relativity addresses how mass behaves under motion, emphasizing that rest mass and relativistic effects are separate concepts. The conversation suggests that a comprehensive understanding of mass must integrate both the Higgs mechanism and relativistic principles. Ultimately, a unifying theory that fully reconciles these aspects remains elusive.
danR
A major part of the takeaway buzz in the popular press—and by a lot of authorities quoted it seemed—was that the Higgs boson/mechanism explained mass (and inertia). I was quite impressed by this fundamental mystery being solved and mentioned it to a prof and he said did not: mass and inertia were completed explained long ago on relativistic grounds, and suggested a lot of hoopla was been made up by CERN for the publicity's sake.
Now it seems to me as I searched this site that the Higgs mechanism explains this mass, that mass, not the other mass, and also not really x,y, z mass, that there might be other Higgs fields, etc.
Is it fair to say that no ensemble of all known and conjectured and unknown Higgs mechanisms taken as contributing to the mass of protons, leptons, tossed baseballs, and rocket sleds, in fact, explain mass and inertia in any complete macroscopic sense? And there is no unifying theory, at least tentative and speculative, that would unify Higgs and relativistic mass?
You are to some extent mixing up two issues. The rest mass of particles and the effects of relativity.
Higgs field gives an explanation for the rest mass of some particles, but it is not the whole story. For example, Higgs accounts for only a small part of the mass of a proton, the rest is due to internal energy from gluons and virtual quarks.
Relativity is concerned with the effects of motion etc. on mass, such as what happens to protons in the LHC.
This is a pretty good explanation of what the Higgs is/isn't.
For example, I just now found the highly respectable BBC at the top of my Google: higgs boson mass search, wherein is the following explanation:
"Mass is, quite simply, a measure of how much stuff an object - a particle, a molecule, or a Yorkshire terrier - contains. If not for mass, all of the fundamental particles that make up atoms and terriers would whiz around at light speed, and the Universe as we know it could not have clumped up into matter. The Higgs mechanism proposes that there is a field permeating the Universe - the Higgs field - that allows particles to obtain their mass. Interactions with the field - with the Higgs bosons that come from it - are purported to give particles mass. This is not unlike a field of snow, in which trudging through impedes progress; your shoes interacting with snow particles slows you down."
and:
" The Higgs boson came about because although the Standard Model holds together neatly, nothing requires the particles to have mass; for a fuller theory, the Higgs - or something else - must fill in that gap" (emph. added)
http://www.bbc.co.uk/news/science-environment-16116236
It sounds like you're saying "yes, the Higgs boson has little to do with why things are massive in a macroscopic everyday sense". But they are talking both of particles and terriers—ensembles of particles, and moreover they introduce motion into the question quite clearly as though there were more involved than simply rest mass. Allowing that they are talking loosely about the contribution of the Higgs mechanism to the totality of rest mass of particles, and supposing we fortify the Higgs mechanism with other like mechanisms, and mechanisms of internal kinetic energy of gluons and quarks, could we say that would explain all the mass of all particles individually, and collectively in large objects?
My 'relativistic' and 'relativistic mass' were poorly chosen. What I meant was mass pertaining to Einstein's relativity in which space, time, mass, energy, and...inertia are bound together in a unified whole. There must be a reason why, when our car battery is dead we have push it hard to get it rolling at a reasonable speed, but once it gets going we can ease off a bit.
This inertia is somehow explained by the distortion (with respect to observers in differing reference-frames, not absolutely) of the 4-space field that doesn't care to be distorted ('...tends to stay at rest', but doesn't appreciate being undistorted ('...tends to stay in motion'). I'm putting it in the crudest layperson's terms, but I think someone in the spirit of Feynman can repair it.
In sum, it sounds to me like a fully amplified microscopic description of mass is in competition with the mass fully explained by Einstein, and there has to be some kind of unification that couples both, to explain the rest mass of a proton over that of a muon in terms of the energy needed to accelerate each to the same speed.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
