Can a Debye Layer Form in Air?
  • Thread starter Thread starter Clausius2
    Air Debye Form
A Debye layer, which involves debye screening, typically requires the presence of free charges in a medium. In neutral gases like air, there are no free charges, only polarizable molecules, leading to dipolar screening instead. This dipolar screening does not significantly alter the potential around a charged particle, as it remains roughly a 1/r potential. The interaction between a charged particle and dipolar molecules in air is generally too weak to create a Debye layer. In contrast, a charged particle in pure water would result in a layer of polarized water molecules, demonstrating debye-like screening.
Clausius2
Just a question:
I do know it is possible to have a debye layer in a electrolyte. But is it posible to have a Debye layer in air?. I mean, if I put a single charged particle in air, do I have a layer of ionized air surrounding it??.
Thanks.
You are talking about debye screening, right? If my memory serves me, the debye screening model assumes the presence of "free" charges in the system - that is an initial condition of the sytem, if I may call it that.
In a neutral gas like air, you have no free charge. What you do have, however, are polarizable molecules (though O2 and N2 have pretty low polarizabilities). This gives rise to dipolar (or dielectric) screening which, unlike debye screening doesn't not really change the functional form of the potential very much (ie: a 1/r potential remains roughly a 1/r potential) . Nevertheless, the charge-dipole interaction is likely to be too weak (compared to KE) at most temperatures to create anything like a debye layer.
Also, I can't imagine there is enough of a field gradient from an isolated charge to ionize nearby molecules.
However, if you put a charged particle in pure water, you would have a layer of polarized (not ionized) water molecules surrounding it (and resulting in debye-like screening of the charge potential). This is essentially what hydration/dissolution involves.
Thanks gokul, I got it. Air is not an electrolyte at all.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
