Getting higher potential difference with Van De Graaff machines
A Van De Graaff (VDG) machine can generate high voltages, potentially reaching millions of volts with minimal energy input. Increasing the machine's size enhances voltage output, but stability becomes a concern beyond 10 million volts. A proposed solution involves a 'magnified' machine design that aggregates charges from smaller VDGs to achieve higher voltages, theoretically up to 100 million volts. This high voltage could interact with deuterium or tritium gas mixtures, potentially leading to fusion reactions. While initial experiments with charge aggregation have been attempted, further testing is needed to confirm the effectiveness of this approach.
stevecheang
Using a Van De Graaff (VDG) machine, we can easily generate million-volt high voltage. The high potential difference can be generated effectively with minimum energy supplied to the machine. The larger the volume of the machine would be, the higher the voltage could get. However, stability would be a problem when the voltage gets to over 10 million-volts. This issue could be resolved with ‘magnified’ machine design. For example,
VDG1, VDG2, VDG3 è VDGA
VDG4, VDG5, VDG6 è VDGB
VDG7, VDG8, VDG9 è VDGC
VDGA, VDGB, VDGC è VDGX
In that case, VDGA works like a magnifier which aggregates the positive charge (or negative charge conducted from smaller VDGs) and collectively ‘magnifies’ the voltage to higher voltage. Of course, a portion of the positive charge could be lost in the process. However, it could theoretically be possible to keep majority of it until the voltage gets elevated to 100 million volts or higher. With such high voltage working on the deuterium or tritium, gas mixture which could be mixed from a source of gaseous catalyst, selected from the group consisting of beryllium, carbonates, hydroxides, halides, sulfates, phosphates, and sulfides. The reaction produces natural lightning, or occasional fusion reaction if you like.
Someone I know was arguing and claimed natural lightning would not produce fusion. First of all, the design described here is not about real natural lightning. You don't get to manipulate real natural lightning with the addition of deuterium or tritium in the picture. Second, real natural lightning has voltage in the range of a few million to at most 10 million volts. You don't get as high voltage as the design theoretically could (if it works).
Someone asked, "Have you tried the theory to magnify the voltage?" I actually tried building a simple VDG and direct the charges to another larger hollow metal ball (not a VDG) successfully. However, I have never tried more than that. Hence, it would be difficult for me to say for sure whether it definitely would work.
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
