What Are the Key Takeaways from My 2-Week HDL Microcontroller Project?
The discussion centers on a student's two-week project involving the design and implementation of a microcontroller architecture using Verilog, featuring a range of instructions and modular components. The student seeks guidance on the project's significance beyond academic purposes and inquiries about the industry's use of Verilog for microcontroller architectures. While the project incorporates RISC principles and Harvard architecture, the student notes the absence of instruction pipelining and opcode prefetching due to design constraints. Participants highlight the relevance of the project for future career prospects in electrical and computer engineering. The conversation emphasizes the importance of practical experience in understanding real-world applications of HDL programming.
Mastermind_14
Hi people!
I am a student of Electrical engineering (5th semester) and have a profound interest in HDL (ie. verilog) Programming. For my 5th semester project of Digital System Design i have designed and implemented a primitive microcontroller Hardware architecture from scratch having...
>All 2 byte instructions
>128 byte ROM
>63 different instructions including Jumps,call/return,push/pop ,CJNE, DJNZ etc(most of 8051 and PIC18f452)
>ALU, ROM and Processor are separate modules inside the main module "IC"
>16 byte deep stack
>8 byte of byte addressible RAM
>1 byte of bit addressible RAM
>Time shared architecture of busses
>Machine cycle of 1 clock cycle
>and many more
This hardware architecture that i have thought of and implemented in Verilog with greatest level of detail was completed in just 2 weeks with little effort which made me eager to explore this HDL even more and pick even more challenging projects. so if you can guide me to some challenging project or want to know about this microcontroller implementation in verilog then please PM me or post to this thread.
Furthermore does this project of mine has any more significance then just serving my academic purposes? If yes then what is the significance? and if no then in what direction should i spend my HDL programming skills such that I might get some recognition ( credited for doing something unique and useful )?
NOTE: An image of the Instruction architecture has also been uploaded to give a vague idea of what I am saying.
You can look into things such as instruction pipelining, datablock moves, high level language hardware layer, intelligent branch select opcode prefetch, risc and parallelism, aisc, dsp architecture, harvard architecture, memory control.
Dear Phrak,
First of All thanks for your reply.Now the thing is that I have already employed
>harvard Architecture
>datablock moves
>memory control
While I did not find any use of
This is because I designed and implemented the architecture in a HDL with no intention of implementing it on FPGA (unless it is worth implementation) so I designed it such that the input and output data throughout the microcontroller is multiplexed on negative level and positive level of the clock respectively. So this cannot be optimized more then a single clock cycle while every process is completed with just zero time delay and pipelining would mean adding latency for no increase in clock speed. Same is the case with prefetching of opcode.
Though I find aisc and dsp architecture the next fields that I should explore so thanks for this suggestion.
I want to know a few more things.
>The main question remains unanswered "Does this project of mine has any more significance then just serving my academic purposes?"
>Is Verilog being currently employed to implement and simulate microcontroller architectures in the Industry? If yes then which companies are doing this?
It wasn't apparent from you initial post what all you'd been doing. I'd though perhaps a bare bones micro, and so the seggestions for what you might pursue. I haven't done any of this in 15 years, so I'm out of this loop, but there are all kinds of games you can play with the clock. The external clock can drive an internal frequency multiplier, so that you can generate multiple internal clocks with edges just about anywhere you want them.
What your doing should give you some background if you intend to pursue a CE. I hope someone else has better answers than I.
I didnt understand what you mean by
Can you please elaborate it.
Mastermind_14 said:
I didnt understand what you mean by ...
I re-read your first post. I see you are an EE student, rather than CE. Either way, it should serve just as well. But next time you speak to an engineer, ask him of what he learned in school applies to his current job.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
