How Do the Gauges of 1PN and Schwarzschild Metrics Differ?
andert
I'm sure there is a simple answer to this question, but I have been looking at the first Post-Newtonian (1PN) metric (for my own research) and noticed that the time-time component of the GR metric is:
g_{00} = -1 + 2U - 2 U^2
where U is the Newtonian potential.
The time-time component of the Schwarzschild metric, however, is
g_{00} = -1 + 2M/r.
There is no quadratic in the Newtonian potential even though this metric is an exact solution of the field equations. Is this because it is in a different gauge?
You can make g00 look like anything you like, just by a choice of coordinates. Suppose I set g00=f(r), where f is some arbitrary function, and I don't give you any other information about my coordinates. You can then use this equation to define an r coordinate. For instance, suppose g00 changes by a factor of 2 between r1 and r2. Then we've effectively defined r=r2 to be the location where gravitational time dilation differs by a factor of 2 from its value at r=r1. With this implicit definition of the r coordinate, we can now go ahead and infer the rest of the metric.
Alright, yes, coordinate system or gauge. I see that. Each of them is a in a specific gauge. Now, what is different about the gauges of the 1PN and Schwarzschild metrics specifically? The 1PN gauge is a harmonic one. So if I were to take a static spherically symmetric field, I would have the 1PN time-time component,
g_{00} = -1 + 2M/r - 2(M/r)^2
Is the idea that, in this special case, we can make a change of gauge (coordinates) to eliminate the quadratic term but in the general case of many bodies (with a sum over masses) we cannot?
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
