How Can the Pigeon Hole Principle Be Applied to This Problem?
  • Thread starter Thread starter karthikvs88
    Hole Principle
The discussion focuses on applying the pigeonhole principle to demonstrate the existence of an integer x satisfying two modular equations, given that m and n are relatively prime integers. Participants clarify that since m and n are coprime, integers p and q can be found such that pn - qm equals any integer, including the difference a - b. The conversation highlights the need to show that the equations derived from the modular conditions can be satisfied. However, there remains uncertainty about how the pigeonhole principle directly applies to the problem at hand. Ultimately, the participants reach a consensus on the existence of p and q, but the specific application of the pigeonhole principle is still unclear.
karthikvs88
Using pigeon hole principle, prove that if m and n are relative prime integers and a and b are any integers, there exists an integer x such that x = a mod m, and x = b mod n.
none
data: m|(x -a) and n|(x-b)
hence we can write, for some integers p and q
x = pn + a and x = qm + b
also, since (m,n) = 1, there are integers i and j such that
im + jn = 1
how do we apply the pigeon hole principle to this problem?
Hello,
I think I have a solution, but I am not sure, especially because I haven't used the pigeonhole principle:(By the way: Some things you list under data (x=pm+a etc), you have to show that, that isn't given.)
We can always say that there is a x such that x=pn+a (for some p). ( Notice your typo.) Oh, by the way: We haven't yet fixed the value of this p.
We have to show that (pn+a)-b=qm, for some q. Or in other words: a-b=pn-qm . Well, as gcd(n,m)=1, we can ALWAYS find p and q such that pn-qm equals any value, in particular a-b.
Hey mathmadx,
I am not aware of this result you have used,
"Well, as gcd(n,m)=1, we can ALWAYS find p and q such that pn-qm equals any value, in particular a-b. "
What I do know is,
"If a and b are integers, not both 0, then gcd(a,b) exists; and we can find integers m and n such that gcd(a,b) = ma + nb."
In this case, as I have stated, there exists integers i and j such that
im + jn = 1
Are you sure that your statement is true?
PS: I have edit my first post to fix the typo.
Hi,
I figured it out, yeah I guess we can always find p and q such that pn - qm equals any value.
Since we can find i and j such that
im + jn = 1
(a-b)im + (a-b)jn = (a-b)
hence our p and q would be (a-b)j and -(a-b)m.
Still don't know how Pigeon hole principle is used here though.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
