How can I generate electricity with wind power?
  • Thread starter Thread starter cusimar9
    Electricity
To generate electricity using wind power, one can utilize a fan or a DC motor with permanent magnets to create a current. Spinning a conductor within a magnetic field or rotating the magnetic field around a conductor can induce electricity. An alternator, which requires initial electricity to operate, can also be used, but it is more complex to set up. For a simple project, attaching a fan blade to a small DC motor can effectively light a bulb. Wind power generation typically requires a battery system to store energy due to its intermittent nature.
cusimar9
Hi,
Can anyone explain to me how I can generate a current (to say, light a lightbulb) by wind power?
I have a fan which is spinning and I know it has something to do with a wire and a magnetic field but I don't know how to set the circuit up at all.
Maybe a simple diagram if anyone has a minute spare?
Cheers
Rick
So. You are wanting to make a wind mill generator? Are you intending on using the fan for the wind source, or will this be an outside device?
If the latter, are you intending to use the fan to generate the power?
That could work I suppose, however, it might be tricky to setup. Is it a typical box fan?
Basically, you can get electrical current by either rotation a conductor (the wire) inside a magnet field, or rotation the magnetic field inside of a conductor.
Chances are, your fan has natural magnets on the shaft of the fan blade. When power is turned on, coils of wire become electrically charged, creating an EM field, which repels the natural magnets. Spinning the fan blade should induce some current inside the coils, however it will probably not be that effiecent.
I watched an episode of "Escape from invention(i think) Island" on discovery. They had to build electric rope cars, and transport themselves across a valley.
Anyhow, part of the challenge was building a water wheel to turn an alternator, which would charge the battery. They provide alternators which were regulated at 12v dc, however, you can get alternators which do not.
I would start out by perhaps using an old fan blade, although it was more designed to push air, as opposed to being pushed by air. Find a way to mount a pulley on it, and get yourself an alternator. Hook a belt from the fan pulley to the alternator, find a windy area, and you've got power.
You might find a multimeter usefull, so you can measure the power being produced. Also, while I recommend the buying an alternator, it is not impossible to build your own, just more difficult.
This site will probably help you a bit
http://www.otherpower.com/otherpower_wind_tips.html
Thanks!
Where could I get an alternator that small?
Its "Escape from Experiment Island" on the Science and Discovery channel (and DHC or others in their little network of channels). :)
Any DC motor can generate electricity as well. With permanent magnets, its very simple as you just need to spin it to generate electricity.
An alternator needs electricity to generate electricity. And you need not worry about size, there is a regulator that controls how much electricity it makes. An alternator is constructed with a spinning coil and a stationary coil. It needs electricity because you use this electricity to turn the spinning coil into a magnet. The spining magnet then causes electricity to flow in the stationary coil of wire.
If you were lighting just a small light bulb like an automotive dome light, you could take the small DC electric motor from a radio controlled car and add a fan blade to that. From there you could adjust the sizes of the components to get the desired results, most likely a larger fan blade than you would have thought necessary.
Wind isn't typically a steady source of power. The units for sale are generally hooked to a battery charger so it can store the energy in rechargeable batteries.
Cliff
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
