Multiples of natural frequency?
An object does not resonate at multiples of its natural frequency because it does not return to its natural state during those oscillations. Ideal systems, like a mass on a spring, resonate at a single frequency, while real structures may not sustain multiple nodes at harmonic frequencies due to their geometry and physical properties. The concept of overtones helps clarify this distinction, as real-world materials can exhibit complex vibrational modes. For example, cymbals are designed to produce a random response rather than a specific note, highlighting the complexity of resonance in two-dimensional surfaces. Understanding these principles requires recognizing the limitations of ideal models when applied to real-world scenarios.
LoveKnowledge
Multiples of natural frequency??
Hi all! I am a little confused. Why will an object not resonate with multiples of its natural frequency?
I think due to the reason that through its multiples, it will not return (even if temporarily) to its natural state...am I mistaken??
Thanks in advance for your help!
Can you think of a reason why is should? What are the conditions for resonance?
There is no reason why an 'ideal' mass on an 'ideal' spring should resonate at any more than one frequency.
If you are thinking about a structure which is based on standing waves, then the geometry and the physical details may well not mean that multiple nodes would be sustained at harmonics of the fundamental. This is why they are given the name 'overtones', to avoid confusion.
For this ideal behaviour you need the speed of waves to be independent of the frequency (a special case) and the ends to be ideal reflectors of the waves which are going back and forth.
Consider a disc of metal. The modes of vibration are very complex and you can produce all sorts of resonances over the two dimensional surface. I believe that this may be a good reason why cymbals are made circular so that they produce a very random-like response to being bashed - with no particular audible 'note'.
Take a very familiar case of water waves in a trough. There is no harmonic relationship at all between the frequencies of the different resonance modes. Try it in the bath next time - when the rubber duck ceases to be fun :smile: Try not to get the stopwatch wet, though.
thx for your explanation. it clarifies things up a bit (I understand it 85% now) but just a little confused still.
Your explanation was helpful though. Thanks for your response. :)
For a 'perfect' string, your ideas hold.
But it gets more complicated as soon as you go away from 'ideal'.
:approve:
