Period of oscillation for a mass on a spring
The period of oscillation for a mass on a spring is influenced by the mass due to the proportional relationship between spring deflection and the attached mass. A smaller mass results in less spring deflection, leading to a shorter oscillation period, while a larger mass causes greater deflection and a longer period. However, the amplitude of oscillation does not depend on the mass but rather on initial conditions. In contrast to a simple pendulum, where the restoring force is directly related to gravity, the mass-spring system's period is independent of the amplitude. Understanding these distinctions clarifies the dynamics of oscillation in different systems.
physics20
Why does the period of oscillation for a mass on a spring depend on its mass? (while in other situations, like a simple pendulum, the mass seems to be unimportant)
Reason is the amount of spring deflection is proportional to the attached mass. If mass is very small, the spring doesn't deflect very much and takes a much short time to complete a cycle than if the mass was large.
because the restoring force for a pendulum is due to gravity
for a larger mass the restoring force is automatically larger.
that is not the case for a mass-spring system
This is a little confusing and mostly not true.
The period does not depend on the spring deflection (amplitude) and the amplitude does not depend on the mass attached but on the initial conditions.
If you have in mind a vertical spring (it does not have to be vertical) with a mass attached, then the mass determines the equilibrium deflection, but this is not in general related to the amplitude or the period of the oscillations.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
