Calculate Skydiver's Velocity After 2 Seconds with k = 1/2 pCdA
  • Thread starter Thread starter chengbin
    Speed
To calculate a skydiver's velocity two seconds after opening a parachute, one must solve the differential equation m dv/dt = mg - kv^2, using the initial condition of terminal velocity (50 m/s). Substituting k with 1/2 pCdA and integrating the equation is necessary, as shortcuts using freefall calculations do not yield accurate results. The correct approach involves recognizing that the velocity function must account for the initial condition of v(t=0) = v_0. The resulting expression for velocity over time can be derived through proper integration techniques. Ultimately, a differential equation solver may be needed for those unfamiliar with the calculus involved.
chengbin
If a person has reached terminal velocity (say 50m/s), and he opens his parachute, and I want to find his speed 2 seconds after he opens his parachute, can I do this?
Solve the equation m dv/dt = mg - kv^2 and substitute k with 1/2 pCdA and substitute the value for p, Cd, and A to find velocity?
If I can, can I do this shortcut to simplify work?
The proper way of doing it would be to solve this differential equation m dv/dt = mg - kv^2 given the condition when t = 0, v = 50. But solving that would be a lot of work, and it is easy to make a mistake somewhere as my calculus skills is rusty. I can find a solution for m dv/dt = mg - kv^2 for when t = 0, v = 0 from wikipedia
http://en.wikipedia.org/wiki/Terminal_velocity
Substitute my values in, I get a number, let that be x. The velocity of a freefall object with no air resistance after 2 seconds is 9.8(2) = 19.6 m/s. The velocity slowed by drag can be found by 19.6 - x. Then I just do 50 - (19.6 - x) to get my velocity after 2 seconds.
If this doesn't work, is there a differential equation solver that will solve my equation? Thanks
It doesn't work this way. The expression you have above is the speed as a function of time if the object starts from rest. One needs to go back to the original differential equation and solve it with the initial condition ##v(t=0)=v_0## to get a new expression for ##v(t)##.
The differential equation may be written as ##\frac{dv}{dt}=g-\alpha v^2##. With terminal velocity ##v_T=\sqrt{g/\alpha}##, and after separation of variables, one gets$$\frac{dv}{v_T^2-v^2}=\alpha ~dt$$This can be easily integrated from ##v_0## to ##v## by separating fractions. The result is
$$v(t)=\frac{\frac{v_T+v_0}{v_T-v_0}-\exp(-2 \alpha v_T~t)}{ \frac{v_T+v_0}{v_T-v_0}+\exp(-2 \alpha v_T~t) }v_T.$$You should be able to get your expression from the above equation if you set ##v_0=0## but it's not easy to guess the form of the equation going the other way.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
