Marinel
- 13
- 0
The problem bellow is a real problem and I would like to get some ideas in order to overcome it.
As you can see in the attached doc, we have two winches ( drum 1 and 2 ) on the same shaft of motor M1, two moving pulleys ( 3 and 4 ) and a fixed pulley (5).
The load is 130 Tons, and we can measure that with a load cell at pulley 5 ( 32,5 Tons) after the lifting of the load.
But during the time as the load is rising we measure only 30 tons! Note that we have a cable of steel with 30mm diam. and the rising speed is about 1m/min.
When we lower the load, the load cell measures 36,2 Tons. and as soon it stops we get again 32m5 Tons.
When the load gets the floor than we read 0 Tons (of course!)
Can someone explain this? This is a real case and my problem is to adjust the safety relay to 110% of nominal load, which is impossible with this beahviour of the system!
