Why is the Arrhenius plot for the rate constant different from y=e-1/x?
The discussion revolves around the differences between the Arrhenius plot of the rate constant (k) versus temperature (T) and the expected form of y=e^(-1/x). The Arrhenius equation, k=Ae^(-Ea/RT), leads to a plot of ln(k) against 1/T, which results in a straight line rather than a simple exponential decay. Participants clarify that the graph's shape is influenced by the relationship between activation energy (Ea) and temperature, which can cause curvature. The confusion arises from the interpretation of the variables and the constants involved in the linear relationship. Ultimately, understanding the logarithmic transformation and the linearity of the Arrhenius plot resolves the initial misunderstanding.
Saitama
This isn't a homework question but this thing is disturbing from a long time.
I attended a class on Arrhenius equation and its plots. One of the plots is disturbing me from long which is the plot between k vs T.
Arrhenius equation:-
k=Ae^{-\frac{E_a}{RT}}
k->Rate constant
Ea->Activation Energy
R->Gas constant
T->Temperature
Since the equation is of the form y=e-1/x, the graph should be like this one:-
Click Here
But my teacher made a completely different plot. I constantly said that it shouldn't be like that. Finally, when i checked wikipedia, to my surprise, the teacher was right. Here's the wiki article:- http://en.wikipedia.org/wiki/Arrhenius_plot
I don't understand why the graph is different from that of y=e-1/x? Can somebody tell me where i am going wrong?
Thanks!
I am talking about this graph from the wiki page:-
No, i don't think this one is log based.
okay so the bottom chart is an arrhenius plot plotting 1/T vs ln(k) as defined in the wiki page and the upper chart is the same data but plotting T vs k.
The only thing I can think of is that Ea changes with the square of T causing it to curve upward.
Hey Pranav-Arora! ;)
Here's another one from WolframAlpha.
http://www4c.wolframalpha.com/Calculate/MSP/MSP82681a10gc2589cc12cc00000dh1e4827i034cf8?MSPStoreType=image/gif&s=20&w=300&h=183&cdf=RangeControl
plot[ y=e^(-1/x), {x,0.2,0.5} ]
Doesn't it kind of look like your graph?
Hello ILS! :)
Oh yeah, that's look like something which i am looking for. You made the graph for very small values of x but i don't think that this is correct because in the wiki graph, temperature is increasing to high numbers but it isn't turning like to be that of y=e^(-1/x).
Ea changes with the square of T? I will have to check that out.
Well, the formula is undoubtedly based on the shape of the graph when plotting ln k versus 1/T.
Then you apparently get the graph:
This is approximated by a straight line.
With the relationship ##\ln k = c_1 - c_2 \cdot \frac 1 T##, you can deduce that ##k=A e^{-\frac B T}##.
When I make an approximation of this, I get the following graph:
http://www3.wolframalpha.com/Calculate/MSP/MSP65161a10geiaaagg40a900000h0fa40fba06a13c?MSPStoreType=image/gif&s=30&w=300&h=191&cdf=RangeControl
plot[ k=18e9 * e^(-13000/t), {t,590,660} ]Doesn't this kind of fit the expected graph?
I like Serena said:
With the relationship ##\ln k = c_1 - c_2 \cdot \frac 1 T##...
How did you get this relation? :rolleyes:
A straight line is defined by the equation:
$$y = a x + b \qquad\qquad (1)$$
where ##a## is the slope of the line, and ##b## is the y-coordinate where the line intersects the y-axis (the y-intercept).When we fit a straight line to a set of points, we try to find out what ##a## and ##b## have to be.In this case we have ##\ln k## on the y-axis, and ##\frac 1 T## on the x-axis.
So we replace ##y## in equation (1) by ##\ln k##, and we replace ##x## by ##\frac 1 T##.
The result is:
$$\ln k = a \cdot \frac 1 T + b$$
Since we already know that the line slopes down, I have taken the liberty of putting in a minus sign, and rewriting the equation with different constants ##c_1## and ##c_2## as:
$$\ln k = c_1 - c_2 \cdot \frac 1 T$$
The result is:
I already knew about the straight line stuff, i was getting confused with those constant c1 and c2.
Thank you for the help! :smile:
