NOOB QUESTION: What kind of resistor do I need?
  • Thread starter Thread starter MikieCGY
    Noob Resistor
To power LEDs for a costume, a 9V battery is not suitable for running 500 LEDs due to its limited capacity. Each LED requires a resistor to limit current, with a suggested value of 120 ohms for individual LEDs. Connecting LEDs in pairs with a 30-ohm resistor can improve efficiency, but even then, the power requirements can exceed what a 9V battery can provide. Alternative power sources, like six D-type cells, are recommended for better energy capacity. Experimenting with lower current levels may allow for more LEDs while maintaining brightness.
MikieCGY
First off.. this is my first attempt playing with this kind of stuff.. please have a bit of patience with me :)
I'm looking to make a costume out of LEDs for burningman.. bought a 1000 of them off ebay and when I connect them the 9V battery I'm guessing is too strong for it and burns the LED out.
is it possible to run say 500 LEDs off of 1 9V battery?
These are the specs of my LEDs (which is another language to me)
WLD : 465-470 NM
IV: 8000-10000 MCD
VF: 3.4 -3.6V
please advise. thanks :)
MikieCGY, Welcome to Physics Forums!
It appears you have the blue LEDs made by China Young Sun LED Technical Co., LTD. Their model (part) number is YSL-R1042B5C-D13. The specification sheet is available at:
http://www.sparkfun.com/datasheets/Components/LED/Blue-10mm.pdf
The LED’s output wavelength, intensity, and forward voltage you mentioned were measured with a current of 80 milliamperes flowing through it. The suggested operating current is 65-75 mA, which would consume 180 milliwatts of power.
Using your 9 Volt battery, to energize one LED you would use a 120 ohm resistor in series with the LED (between the battery and the LED) to limit the current to around 70 mA.
No, you cannot run 500 LEDs off one 9 battery! A typical alkaline 9 V battery has the capacity of 565 mAhr, meaning it can supply 565 milliamps for one hour. So if you connected eight circuits like the one described above in parallel they would operate for about one hour. You will have to either use bigger batteries or fewer LEDs, or both. Have a good time!
p.s. I went to Burningman in 1982 and had a fantastic experience! I wore a ball cap with a solar cell powering a tiny dc motor with a plastic propeller on top.
Thanks for the quick reply Bobby! Also going to a hobby shop today in hopes of buying some resistors instead of buying them online..
does each LED need its own resistor?
How many LEDs can one 9V battery power?
Can you suggest a different power source?
Looking forward to the burn.. its definitely grown since 1982 ... been wanting to go for a fe years now and finally going this year
I'm pretty crafty but my electronic knowledge is just god awful :(
thanks!
You could run LEDs in pairs, connected in series with a 30Ω resistor from 9V, that would be more efficient on your power. You would get twice the bang per buck? Each pair would take about 70mA.
250 pairs would need 17A. That represents 17X9 = 150W+, which would be totally daft and would fry you, even if you could carry all the batteries needed! You wouldn't need anything like as many as that. You could get a good show with twenty pairs, which would draw 1.4A (12w).
Actually, you would be better to experiment with just how little current you could get the LEDs to light up at all then use more. That would depend upon the exact behaviour (rather than the published spec) of the LEDs.
AS a power source, six D type cells would be better than 9V batteries and you can get holders for them. You would be well advised to use a fuse in the circuit - just next to one end of the battery pack. D type cells hold a lot of energy and you don't want to be dressed up in a potential crematorium if you get a short circuit somewhere!
To save on current drain it may be worth while pulsing the diodes and accepting the reduced brightness so that you can use more light sources all over you. But you'd need an oscillator / switching circuit, which may not be straightforward for you.
Hi there, it's great that you're getting into electronics and experimenting with LEDs! To answer your question, the type of resistor you need will depend on the specific circuit and components you are using. Factors such as the voltage and current requirements of your LEDs, as well as the power source you are using, will determine the type and value of resistor needed. I recommend doing some research on LED circuits and consulting with experienced individuals to determine the best resistor for your project. As for running 500 LEDs off of 1 9V battery, it is possible but you will need to consider the voltage and current requirements of your LEDs and make sure your battery can supply enough power to run all of them. It may also be helpful to use multiple batteries or a different power source for such a large number of LEDs. I hope this helps and good luck with your project!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
