Why is copper tubing used to make high q antennas?
  • Thread starter Thread starter baconman71
    Antennas Copper
The discussion centers around the reasons for using copper tubing in the construction of high-frequency antennas and coils, comparing it to other materials such as normal wire and aluminum. The scope includes technical explanations related to conductivity, resistance, and practical considerations in antenna design.
  • Some participants propose that copper has higher conductivity than most metals, which may contribute to its use in antennas.
  • Others mention the "skin effect," where current primarily flows in the outer layer of the conductor, suggesting that the surface area of tubing may be advantageous.
  • One participant notes that aluminum is often preferred for its light weight and strength, particularly in tubular form, despite its corrosion issues.
  • Another participant argues that conductivity differences between good conductors may not significantly impact performance, as skin depth is also a factor.
  • Some contributions highlight that copper tubing is favored for its reliability in electrical connections, as it can be easily soldered, unlike aluminum.
  • Concerns about copper tarnishing and its higher cost compared to aluminum are also raised.
Participants express differing views on the advantages of copper versus aluminum, with no consensus on the primary reasons for using copper tubing in high-frequency antennas. Some agree on the benefits of copper for reliable connections, while others emphasize aluminum's advantages in weight and cost.
Participants mention various factors such as skin effect, surface area, and practical challenges in soldering aluminum, indicating that the discussion involves multiple technical considerations that are not fully resolved.
baconman71
My question is just what the title says. Why is copper tubing used instead of normal wire or enameled wire to make antennas and coils at high frequencies? Does it offer less resistance than normal wire?
copper has higher conductivity than nearly any other metal than silver (and silver is only marginally better). at high frequencies, there is a lot of "skin effect" where the great majority of the current flows in the outside layer of the conductor and the internal part of the conductor has nearly no current.
but i always thought that these high-frequency antennas were made out of tubular aluminum, because Al is light and, in a tubular shape, it is strong, to stand up to wind, etc.
i don't think copper is used too much, simply because it tarnishes when exposed to air over long periods.
Tubing is mostly used for strength. Like rbj, I haven't seen much in the way of copper tubing used for antennas, except for J-Pole antennas where you need to weld two pieces of tubing together...
I don't think conductivity play much roll in this. Conductivity goes up, skin depth goes down. It all null out particularly the conductivity is not that big a difference between good conductors. Most common rod antenna like rabbit ear are not copper! Skin depth is:
δ_s=\frac 1 { \sqrt{\pi f \mu σ}}
and is substantially more expensive than aluminium!
Berkeman, I do have one copper tube antenna, a 40m band magnetic loop :)
Dave
Copper tubing is used instead of copper wire because it has a much lower resistance.
Because of skin effect, the resistance of the tubing or wire depends on the surface area of the conductor and tubing has a much greater surface area than wire, for the same length.
Copper is used instead of aluminum where a reliable electrical contact is needed. It can be easily soldered and connected to a feedline where copper conductors are also used.
Aluminum can be soldered with great difficulty and it corrodes rapidly, especially near the sea.
It is lighter and cheaper than copper, though, and is used for TV antennas where periodic replacement due to corrosion is acceptable.
Agree, particular aluminum is next to impossible to solder. I was told that you have to scrape the surface under oil and solder under oil after scrapping the surface to prevent oxidation of the surface. Tube for the same weight has a lot more surface area than solid wire.
  • · Replies 44 ·
  • · Replies 25 ·
  • · Replies 72 ·
21K
  • · Replies 24 ·
