Why does a stone tied to a string not fall?
  • Thread starter Thread starter utkarsh5
    Fall String
When a stone is tied to a string and spun in a horizontal circle, it does not fall due to the balance of forces acting on it. The tension in the string pulls at an angle, providing both the centripetal force needed for circular motion and counteracting the stone's weight. This results in a vertical acceleration of zero, meaning the stone maintains its height. The string's angle ensures that the vertical component of tension equals the gravitational force acting on the stone. Understanding this concept clarifies why the stone remains suspended while spinning.
utkarsh5
when we tie a stone to a string and spin it,it does not seem to fall.why does it happen?i mean to say that,no matter how great its horizontal velocity and centripetal force is,the vertical component of the acceleration won't be affected.it means that the stone should keep falling no matter how hard it is spun.why does it happen then?
Here the falling force (gravitational) is being balanced by centripetal force. Hence do not fall.
The string can never be completely horizontal, instead it's at some angle, and the vertical component of tension equals the weight of the stone (assuming steady state). It might be easier to understand this if you imagine that the stone is moving slowly, with the string nearly vertical, following the shape of a cone as the stone moves in a horizontal circle.
rcgldr, you are right
but, utkarsh5 is asking about
when the stone is spinning in a horizontal circle why doesn't it fall, means what makes the stone to gain height.
rcgldr gave the right answer. When the stone is making a horizontal circle, the string pulls at an angle, supporting the stone's weight as well as providing the centripetal force. The vertical acceleration of the stone is zero.
thank you for your answers!now i understand the concept!thank you!
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
