Can Wet Cloth on a Telescope's Mirror Speed Up Cooling?
  • Thread starter Thread starter gloglo
    Cooling Mirror
Using a wet cloth on a telescope's mirror may not effectively cool it, as the glass is a better conductor than water, which could act as an insulator. Instead, wrapping the mirror's backside with aluminum foil to maximize contact with the glass is recommended for better heat transfer. The cooling effectiveness of water also depends on humidity levels; in low humidity, it can promote cooling, while in high humidity, it may hinder it. Allowing the mirror to cool naturally before observing is a common practice among amateur astronomers, as it prevents stress on the optics. Maintaining a temperature balance between the mirror and surrounding air is crucial for optimal resolution during observations.
gloglo
As an amateur astronomer I want my primary mirror (diameter 37 cm) to maintain the same temperature as the air. Small fans on the backside do the job. Only, the air cools quicker during the night than the 1.5 cm thick glass.
Do I obtain a slightly lower temperature on the backside by sticking something wet (cloth?) on the backside, where the fans blow? And thereby cooling the mirror somewhat quicker.
Wet skin, or wet clothes on my skin feels colder when it blows. But does the same principle apply concerning my solid mirror?
Science news on Phys.org
edit: Read post #3 before #2!I can't see water doing anything but insulating it. The glass itself is a much more effective conductor. I'd suggest wrapping the backside with aluminium foil, trying to make as much contact with the glass as possible. I think that would work a lot better than water.
If the humidity is low, then your water idea will promote faster cooling. Google "swamp cooler" to understand why. If humidity is high, then you will have the opposite effect.
Hi there gloglo
Welcome to PF
there are 2 common way to cool the scope and optics before observing
1) for those fortunate enough --- have the scope set up in its own observatory
2) for the less fortunate like me, who can build an observatory because I rent the property
I generally take the scope outside several hours before the planned observing time ... ie. before dark... and let the scope and optics cool down naturally along with the surrounding air.
This has a the advantage that its gradual cooling that doesn't stress the optics and tube assy
cheers
Dave
Pointing the scope at a blank section of sky can let the mirror cool by radiation. Just a thought.
Thank you for answers.
I always let the primary mirror cool naturally a couple of hours, before I stow all the parts (Dobsonian) for a short ride to my favourite secret dark observing site, away from street lamps and stray light. A matter of 10 minutes´ride. Then it is assembled, its small fans started, and again it is allowed to cool while I am making time consuming preparations.
I can not at any time measure the temperature in either the mirror or the thin layer of air just above the mirror surface. But I think I start off with approximately the same temperature those two places.
However, during the session the air gradually cools a bit. So does the mirror, but slower. An ever so small difference in temperatures mirror / air has a negative impact on the resolution.
If I could make the backside of the mirror a bit cooler than the surrounding air, I might keep up with the air cooling. I do not want to blow colder air on the backside, since it would slip past the mirror and cool the air in front.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
