Find Length of Altitude from A to BC in Triangle
  • Thread starter Thread starter justinh8
    Geometry
To find the length of the altitude from point A to line segment BC in the triangle with vertices A(1,-1), B(0,5), and C(-3,0), one must first determine the equation of line BC and the point of intersection (POI) with the altitude from A. The method involves translating the coordinates to simplify calculations, calculating the area of the triangle using the formula involving the coordinates of points B and C, and determining the length of base BC. The area is then used alongside the base length to find the altitude using the formula for area in relation to base and height. The discussion emphasizes the importance of understanding the process rather than simply providing a complete solution.
justinh8
Geometry Question?
A triangle has vertices, A(1,-1) , B(0,5) and C(-3,0). Find the length of the altitude from A to BC.
You must find the POI of the altitude and BC: that's the hint
So basically i have no idea how to do this...
i got 4.3... but its wrong
Mathematics news on Phys.org
Maybe you would have a better idea of how to continue if you would literally draw the graph. Segment BC forms a line. Can you find the line perpendicular to the line BC which contains the point A? Also what is the equation for the line BC?
first translate all the points so that one rest on the origin (0,0) this can be easily done.
take A(-1,1) and translate it to (0,0) by adding (1,-1) to it.
this same translation must be used to change ALL the other points so B becomes (0+1,5-1) = (1,4)
then C becomes (-2,-1)
then draw your graph of the triangle with A in the origin
this means you only have two co-ordinates to work from B(1,4) and C(-2,-1)
now with these two points you get the area by using this formula 1/2(xb(yc) - xc(xb))
basically multiply the x coordinate of B (1) by the y coordinate of C (-1) this gives you an answer of -1 then you take away the product of the x coordinate of C (-2) and B(4) which is -8 so you have -1-(-8) so you have 7 divide this by 2 and you have 3.5 units as an area.(remember here that all of these answers are positive as it is area so in another question if you had -7 divided by 2 your area would still be +3.5)
now you can use this equation to find the length of the base (in this example i'll use BC as the base) sqrt((xc-xb)^2 + (yc-yb)^2) so here you have (-2-1)^2 which is (-3)^2 so you have 9 + (-1-4)^2 which ends up as sqrt(9 + 25) = 6 so your length BC is 6.
Now it's simple use your formula half base multiplied by height is area
you have area and you have the base so your unknown is height(altitude)(H)
3.5(area) = 1/2(6) (BASE) * H
3.5= 3*H
H=3.5/3 which is 1.166666666'7 I may have the answer wrong double check it but the method is right (although there are other methods) Try it yourself on paper(computers make maths harder to do) and see what answer you come up with
find area and base then use the formula area=1/2 base*height
3.5= 3*H
Just FYI, I see that you are new to the forum so perhaps are not aware of it, but it is against policy here to spoon-feed answers. The point of this forum is not to give full worked out answers but to give help that will lead folks to being able to get the answers themselves. In other words, give hints, or a first step. Do NOT give a full worked out answer.
oh no sorry I didn't realize that will I delete my post?
I wouldn't bother deleting it. It's done now, and if the OP has email notification turned on, it's already been delivered to him via email.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
