Centre of gravity of a submerged body?
The discussion revolves around the confusion regarding the calculation of the center of mass for a submerged body. It highlights that the provided notes do not clarify how to determine this center, leading to misunderstandings. A key point raised is the distinction between the center of mass and the center of buoyancy, suggesting that they are not the same. The inquiry seeks a clear method for finding the center of mass specifically for submerged objects. Understanding these concepts is crucial for accurate analysis in fluid mechanics.
derRoboter
Hi guys,
I can't get my head around the centre of mass of a submerged body at all. the notes I've been given don't actually state how you calculate the centre of mass of the submerged body at all and just state it with no decernable pattern. I did assume that it was the centre of mass of that which is not submerged but that doesn't seem to be the case according to some of the diagrams I've been provided with.
how do i find this point?
Cheers
Why would the center of mass of an object have anything to do with whether or not it is submerged or above ground or in outer space?
Perhaps you are thinking of the center of buoyancy, not center of mass?
Thread 'I need a concave mirror with a focal length length of 150 feet?'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
