How does density affects gas pressure?
Higher gas density results in more gas molecules within a given volume, leading to increased collisions with container walls and, consequently, higher gas pressure. This relationship is supported by the ideal gas law, where pressure is proportional to the number of molecules per unit volume when temperature is constant. Gases with greater mass, due to higher density, exert more pressure upon impact with the walls due to changes in momentum. Thus, the increase in density directly correlates with an increase in pressure. Understanding this principle is crucial for grasping gas behavior in various applications.
threy
When density is higher, the gas contains more gas molecules. Gas molecules collide with the walls of container to produce an average force known as gas pressure. Therefore the increase in gas molecules will result in the increase of pressure because the rate of collision is higher. Is that right?? Please help.
Equation of state for an ideal gas: p=ρRT
Yes. That is right. More molecules hitting a given area on the wall per unit time and delivering the same impulse on average per hit means a higher force per unit area.
If temperature is kept constant and if the size of the gas molecules is small compared to the space between them, pressure is approximately proportional to the number of gas molecules per unit volume.
Density is mass per unit volume,
Let me take two gases of unit volume, having different densities,
The gas which has less density has less mass,
The gas which has more density has more mass,
when these gas molecules hit the wall, because of change in momentum pressure will be applier on the wall,
change in momentum = m x ΔV
which ever gas has more mass applies more pressure on the wall,
hope it clears your doubt...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
