Exploring the SU(2)_L x U(1)_Y Gauge Field Theory of Electroweak Interaction
americanforest
What does it mean to say to say that the electroweak interaction is described by a gauge field theory based on the SU(2)_{L}\timesU(1)_Y symmetry group?
I know that SU(2) is a group of unitary matrices and U(1) is the circle group but I don't really see what the sentence means. I haven't taken any quantum mechanics but an doing research on Higgs decays and would like to gain a bit more understanding.
anybody?
You are asking people to explain Wienberg-Salam theory to you! Given the fact that you "haven't taken any QM", this would be an impossible task to achieve.
To understand "why" Wienberg & Salam chose the gauge group SU(2) X U(1) for their model, the following is required;
1) QM
2) QFT
3) The gauge principle ( abelian & non-abelian)
4) Group theory
and, if you to understand the whole W-S model, you also need
5) The Higgs phenomenon.
How do you do that without understanding QM?
regards
sam
ok, if you just want to understand what this statement means then:
the keyword in this sentence is gauge field theory. The group can be any (Lie) groups really, but gauge invariance means a lot. Suppose you have a group transformation operator, U(\vec \alpha) = \exp (i \vec \alpha \cdot \vec g) where
\vec g = (g_1, g_2, \ldots, g_n) and the g_i is a generator of the group G. here \vec \alpha = (\alpha_1, \alpha_2, \ldots, \alpha_n) is just a list of parameters. now if a transformation under U(\vec \alpha), say
\psi'(x)=U(\vec \alpha) \psi(x) leave your overall Lagrangian (say a Dirac Lagrangian) invariance, then we say the Lagrangian is invariant under a global phase transformation. Now what is this Lagrangian, it is unimportant for someone who do not know Quantum Mechanics. But what is important is that suppose you have some Lagrangian which is made up of some combinations of the \psi(x) field and its conjugate put together in such a way that when you apply U(\vec \alpha) to them the overall Lagrangian won't change (of course this needs not happen, but let's assume it does).
now we can go further and ask whether each \alpha_i are just numbers or can they be dependent on x (the position coordinate) as well? In general, you will find that the Lagrangian under such transformation as U(\vec \alpha(x)), do change and in order to keep it invariant, you need to introduce a gauge field and the associated gauge transformation of this field. So everytime when apply U(\vec \alpha(x)) to \psi(x), you also apply this gauge tranformation to your gauge field. Now if the overall Lagrangian remains unchanged after these series of tranformations (local gauge transformation), then we say it is gauge invariance. (ok... that's all you really need to know, without seeing the maths)
Now, the obvious by-product of the above process is the introduction of the gauge field which turns out to be, in the SU(2)xU(1) case, corresponding to the electroweak force. So, to answer your question as to what that initial statement means, it is nothing but saying that the gauge field associated with the SU(2)xU(1) group (when you apply this symmetry it leaves the appropriate electroweak lagrangian invariant) turns out to be the electroweak force we observed in reality.
people are motivated to look at this because for quantum electrodynamics (QED), the group is U(1)_Q where Q means charge. And it is known for a while that local gauge invariance is exactly how to explain electromagnetic interactions. Electroweak and SU(2)xU(1) is a great triumph for physics and symmetry.
NB: the generators for SU(2)_L\times U(1)_Y (for electroweak) are the pauli spin matrices and hypercharge Y (whatever that means.. but the key point is that it is different from Q)
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Is it possible, and fruitful, to use certain conceptual and technical tools from effective field theory (coarse-graining/integrating-out, power-counting, matching, RG) to think about the relationship between the fundamental (quantum) and the emergent (classical), both to account for the quasi-autonomy of the classical level and to quantify residual quantum corrections? By “emergent,” I mean the following: after integrating out fast/irrelevant quantum degrees of freedom (high-energy modes...
