How to Calculate Percent Error in Measurements
  • Thread starter Thread starter Joza
    Error Percent
To calculate percent error in measurements, divide the absolute error by the actual measurement and multiply by 100. For example, if measuring a distance of 20.2 mm with a meter stick, the absolute error is 1 mm, leading to a percent error of approximately 4.95%. A meter stick is accurate to the millimeter, making 1 mm the smallest division for error estimation. The formula for relative error is the absolute error divided by the actual measurement. Understanding these calculations helps in assessing measurement accuracy effectively.
Joza
How does one calculate percent error in measurements?
In attempting to measure a distance of some centimeters with a meter stick, how could I estimate it?
Isn't a meter stick accurate to the millimeter?
Well, if you use the millimeter marks to measure that distance, the maximum error that you could have would be 1 mm.
That's tolerance interval. It's not a percentage. I think, but don't know, but if you measure 20.2 milimeters on your measuring stick, and the most you can be off by is 1 mm than your percent error is that 1mm over 20.2 gives you percent error of.049, or 5%.
MagikRevolver is correct.
The relative error is simply the absolute error divided by the actual measurement (the value of the thing you are measuring).
Absolute error is the amount of physical error in a measurement. The absolute error in your case is the smallest division of the meter stick, or 1 mm.
Hence, the relative error in this case is 1 mm/x mm where x is your actual measurement.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
