Understanding AGC in Communication Receivers
  • Thread starter Thread starter erece
    Communication
Delayed automatic gain control (AGC) in communication receivers refers to a system where the AGC voltage is activated only after the signal reaches a specific level, preventing gain reduction for weak signals. This mechanism utilizes a low pass filter with a time constant of about 1 Hz to manage the forward gain of a variable gain amplifier, introducing a delay in the AGC response. Some participants argue that the term "delayed AGC" is misleading, as the delay is not temporal but rather in voltage response, and they express concerns about potential overshoot and oscillation effects from time delays. The discussion highlights the necessity of AGC across all signal levels to maintain consistent audio output, while also noting that certain modulation types may not require AGC, opting instead for limiting techniques. Overall, the conversation emphasizes the balance between effective AGC functionality and the potential drawbacks of delay in signal processing.
erece
What is the purpose of delayed automatic gain controller (AGC) in communication receiver ?
Delayed AGC is a bit of a misnomer. The AGC is delayed, not in time but in voltage. All it means is that the signal level must reach a specified value before an AGC voltage is developed. The purpose is to prevent the AGC voltage from reducing the receiver gain for very weak signals.
See figure 1 in this paper.
http://www.eecg.utoronto.ca/~kphang/papers/2001/martin_AGC.pdf
The low pass filter, with an integration time constant of the order of 1 Hz, controls the forward gain of the variable gain amplifier. The time constant introduces the AGC delay.
Bob S
Bob, I still don't agree. The only reference to delayed AGC in your reference is in the second sentence on page VI which says, "AGC systems that include a reference voltage inside the control loop are referred as delayed AGC." Unless I am missing something, I don't believe the addition of a reference voltage will cause a time delay in the AGC action. Its purpose is to disable the AGC at low signal levels.
I am not aware of any AGC systems in which a time delayed AGC is desired. True, in AM, SSB or QAM, the desired amplitude modulation needs to be filtered out of the AGC and that results in some time delay, but the delay introduced by the filtering is not desired. Time delayed AGC results in overshoot and if severe enough, oscillation.
I believe the AGC is needed at all input signal levels to maintain a constant audio output signal level.
The AGC signal control voltage is supposed to be an average over a second or two. Causality requires that averaging produces a delay. Anything faster than this will distort the audio signal. This is why there is an RC low-pass filter in the feedback loop. Too much gain in the feedback loop will make it unstable.
Bob S
Bob S
For amplitude modulated signals this is true and many FM receivers don't use AGC, just limiting. However I once designed a nearly instantaneous AGC to be used in a TDMA receiver to compensate for changes in signal level in successive time slots. That AGC used a sample and hold at the peak of each cycle of the signal in the IF.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
