Calculating momentum before and after a collision
The discussion focuses on calculating momentum before and after a collision involving a 1200 kg car and a 2000 kg truck. The total momentum before the collision is the sum of the individual momenta of both vehicles, as momentum is conserved in collisions. If the car and truck lock bumpers, their combined mass becomes 3200 kg, and their speed can be determined by dividing the total momentum by this combined mass. In a scenario where they do not lock bumpers, the final speed of the truck can be calculated based on the car's post-collision speed of 5 m/s. Understanding these concepts is crucial for solving the problem accurately.
sdoyle1
A 1200 kg car traveling north at 14 m/s is rear-ended by a 2000 kg truck traveling at 25 m/s.
a) What is the total momentum before and after the collision?
b)If the car and truck lock bumpers and stick together, what is their speed immediately after the collision?
c) If the care and truck do not lock bumpers and the velocity of the car after the collision is 5 m/s, what is the speed of the truck after the collision?
I'm stuck on the concepts and my teachers hasn't gone into detail in class yet. If someone can explain the concepts then I can probably figure out the math.
Momentum is a vector quantity. In this case, you only have one component to worry about.
Formula for momentum P = mv
Also, momentum is conserved in collisions so the net initial momentum of the system is equal to the net final momentum.
so would part a) just be a sum of both momentums? Or would I add the masses to get a total mass and multiply it by the total velocity (for both the truck and the car)?
Momentum of a particle is defined as the product of the mass and velocity of an object.
The law you will have to use here is the "Law of Conservation of Momentum."
It says that for a system, if net external force acting on it is 0, total momentum will remain constant.
Newton's second law (in original form) is: F = - \frac{dp}{dt}
If p is constant, F=0.
yes it will be sum of momenta of both truck and car
Ok, I have figured out part a. How would it change if the bumpers stick together? Would the mass be the 3200 kg? How about the velocity? Would it just be the total momentum divided by the total weight?
this is how collision will work:
truck is moving at higher speed than car. they collide, speed of truck dec. and that of car inc. and at some moment their speeed become equal.
then after that, car's speed inc. and that of truck dec and car starts moving faster than truck
so if they are locked together they will now have same speed and mass as sum of both car and truck
