Effect of material size on magnetization
The discussion centers on the relationship between the size of ferromagnetic materials and the magnetic fields they generate. It highlights that while saturation magnetization appears size-independent, cutting a material could seemingly double the magnetic field, which contradicts expectations. The conversation explores how the number of magnetic dipoles increases with the cube of the material's dimensions, while the field strength from each dipole decreases with the cube of the distance. Additionally, it examines the implications of separating coils in an electromagnet, noting that the total magnetic energy remains constant despite the increase in flux. The key takeaway is the complexity of magnetization and energy distribution in ferromagnetic materials as size changes.
Liam89
I'm a bit confused about the effect of the size of ferromagnetic material on the magnetic field it generates so I was hoping someone could explain it to me.
The saturation magnetization is given by
M = \frac{N}{V}*μ
but this suggests that the magnetization is independant of the size of the material, but since
B = μ0(H + M)
and since B fields add up vectorially this would suggest cutting a piece of ferromagnetic material in two would double the magnetic field, which doesn't make sense, so I was wondering what I was missing?
What makes sense is that magnetized material can be thought of as composed of elementary magnetic dipoles m packed together with uniform volume density, so the number Nm of such dipoles goes as r3 - the cube of linear dimensions of a sample of characteristic length r. You know I take it that the field strength of each dipole m drops off with distance as 1/r3. So guess what one finds when combining those two factors.
M = \frac{N}{V}*μ
B = μ0(H + M)
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/solenoid.html
The formula shows that for a long (L >> R) electromagnet: B=μ0 N/L I.
Perhaps I can use this formula for your case and say that if the current remains the same but N increases, what will happen? As long as L also increases B will remain the same.
So now if I then separate this long electromagnet into 2 (still long) electromagnets, with the currents still the same value, how much is B for each separate coil? Well it’s the same as before.
An interesting thing is: what happens to the flux when I separate? Answer: since: φ = B x A, it looks like if we separate these coils far enough we have twice the amount of flux. How much is the total magnetic energy of the coils before and after separation? Answer: the same.
Question: what happened to the energy I needed to separate the coils?
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
