How Can You Calculate 'c' for Given 'n' in This Number Series?
  • Thread starter Thread starter Big-Daddy
    Series
The discussion focuses on calculating the value of 'c' in relation to 'n' in a specific number series. The initial values provided show a pattern where 'c' varies based on 'n', leading to a proposed formula of c=(n^2/4)+1. The challenge lies in adjusting this formula to account for odd values of 'n', requiring a function that subtracts 0.25 for odd 'n' and adds nothing for even 'n'. A solution was eventually found, suggesting the adjustment can be made using the expression -((1+(-1)^(n+1))/8). The thread concludes with the problem being resolved.
Big-Daddy
I hope the title is not too confusing. I couldn't think how to summarize this problem.
If n=2, c=2 (sum of 1+1)
If n=3, c=3 (sum of 1+1+1)
If n=4, c=5 (sum of 1+2+1+1)
If n=5, c=7 (sum of 1+2+2+1+1)
If n=6, c=10 (sum of 1+2+3+2+1+1)
My issue is, what is c in terms of n?
So far I've had an idea:
I could propose c=(n2/4)+1, but now I need some way of removing the extra 0.25 that crops up for all odd values of n. What I need now is a little piece which =-0.25 if n is odd and =0 if n is even.
Since (-1)n=-1 if n is odd and 0n=0, I would appreciate a function b of n such that c=(n2/4)+(b)n*0.25. b would evaluate to -1 if n is odd and 0 if n is even.
Alternatively any solution would be welcomed!
Edit: I've solved it, don't worry. [SOLVED]
Mathematics news on Phys.org
How about -(\frac{1+(-1)^{n+1}}{8})
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
