Accurate position change for accelerating objects
To accurately determine the position change of an object experiencing unpredictable forces, the formula x_{2}=\frac{1}{2}at^{2}+vt+x_{1} can be utilized, where 'a' is instantaneous acceleration, 'v' is instantaneous velocity, and 'x_{1}' is the current position. The challenge arises in ensuring consistent position values when using unequal time intervals, such as a single 2 ms interval versus two 1 ms intervals. An effective approach is to model the accelerations and calculate an average acceleration over small time steps. This method allows for flexibility in step sizes while maintaining accuracy in position calculations. Ultimately, a reliable model of acceleration is essential for achieving consistent results across varying time intervals.
Droctagonopus
If an object is subject to different forces at different times and these forces are totally unpredictable (the force at any instant after the current time cannot be predicted). How would we make the position change due to acceleration as accurate as possible?
I have chosen a method but I've encountered a problem.
Use x_{2}=\frac{1}{2}at^{2}+vt+x_{1} where a is the instantaneous acceleration, v is the instantaneous velocity, x_{1} is the position at the current time and t is a very small time interval. However, I need a way to find the same position value after unequal time intervals. Meaning that if I take a single 2 ms interval in one case and two 1 ms intervals in another, the final value doesn't have to be too accurate but it has to be the same for both cases. Is there an efficient way to do this?
You will need some model how your accelerations look like. Different step sizes are not an issue with your formula, if you know an average acceleration within (small) timesteps.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
