What do the peaks in the reflectance spectrum of silicon samples represent?
hjelmgart
Hello,
I am currently analysing some relfectance data I obtained from measurements on several silicon samples. During the process I used the standard fresnel coefficients, and suddenly I began to wonder, what the peaks describe? The last graph at this link shows it for normal incident light, I think.
My typical approach is to relate peaks to the band gap, but then I remembered silicon has a band gap of 1,1 eV.
So what explains the peaks? I am still thinking, that it is related to the band gap. But the band gap isn't constant either? The 1,1 eV is just the lowest gap, right?
So do the peaks represent different band gaps with respect to the brillouin zone, or how is it?
Any suggestions or explanations appreciated! Or possibly a source, that explains it, as I so far had no luck at finding such.
One reflectivity peak is due to a peak in the real refractive index, the other is due to a peak in the imaginary refractive index: and that the formula for calculating reflectivity applies for real- and complex-valued refractive indices.
Note too, that the real and imaginary refractive index components are linked via the Kramers-Kronig relations.
Claude.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
