Classical Poissonian Process: Time-Dependent ω
  • Thread starter Thread starter aaaa202
    Process
The classical Poissonian process describes a scenario where an event occurs with a probability proportional to a small time interval, leading to the decay probability P(t) = exp(-ωt). When the decay rate ω is time-dependent, the probability function changes accordingly. The differential equation governing this scenario is P'(t) = -ω(t)P(t). The general solution for the time-dependent case is P(t) = exp(-∫₀ᵗ ω(u) du). This highlights how varying decay rates influence the overall probability of an event not occurring over time.
aaaa202
I think the classical Poissonian process is where you have something, which in a time dt has a probability ωdt. Then one can show quite easily that the probability that the "something" has not yet decayed goes as P(t)=exp(-ωt), because it obeys a differential equation with the given solution.
However, what does P(t) look like if ω is time dependent?
Mathematics news on Phys.org
Just like before, you have to solve the differential equation P'(t) = -\omega(t)P(t). The general solution is P(t) = \exp\left(-\int_0^t \omega(u)\,du\right).
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
