Where can I find the signal detection point on a SatFinder WS-6903?
  • Thread starter Thread starter Ravaner
The discussion focuses on locating the detected signal point on the SatFinder WS-6903 for use in a radiotelescope application. The user seeks schematics or guidance on tapping the signal before it is digitized and displayed. Challenges include the complexity of the device with numerous SMD components and a microcontroller. The user specifically needs the amplitude of the signal for automatic gain control (AGC) purposes. Overall, experienced insights or schematics for this model are requested to facilitate the task.
Ravaner
Hello. In a radiotelescope application I need to get the detected signal in a SatFinder WS-6903. probably just before digitizing and display. If someone owns the schematics or knows where is this point on PCB ...
At those frequencies, I doubt there is a point where you can easily tap off a signal. Do they make any versions with a USB interface or some other way to communicate with the microprocessor inside?
Hi. In fact I did that job already on more classical sat finder with analog display (µ amp meter) . This one is more complicated, with many smd and double face components. Finally it's always the same chain :filtering, voltage doubling (Schottky diodes), amplification, display. I really need an experienced reply for this device, or better the schematics.
I need to get the detected signal...
are you after the signal content or just its amplitude as in AGC ?
Hi. I only need its amplitude, as I wrote it's a simple detection (AGC is a good example). Problem is that on my new sat finder WS-6903 there are to many components (µcontroller ...) and to find the place of this signal is not an easy game to play
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
