CM and Relative Coordinates; Reduced Mass
Midas_Touch
Two particles of mass m1 and m2 are joined by a massless spring of natural length L and force constant k. Initially, m2 is resting on a table and I am holding m2 vertically above m2 at a height L. At time t=0, I project m2 vertically upward with initial velocity v0. Find the positions of the two masses at any subsequent time (before or either mass returns to the table) and describe the motion.
okay, so i set up the equations and motions and used langrangian equations to yield y = c0+c1t-1/2gt^2
where co and c1 are constants. so for this equation, i have to take the first derivative and plug in t=0. so does that mean, y = c0 and y' = c1?
further, i let the centrifugal force equal to the spring force
F_r = mu*(r'') = -k(r-L) where mu is m1m2/M where M = m1+m2
where L is the unstretched length
anyway since the equation is a simple harmonic equation, i could find two constants b1, and b2 and i got b1 = r - L and b2 = r'/w ( where w =omega) when i plugged in t=0 for the derivatives.
however, how do these initial conditions fit in with the answer, with the position equations y1 = Y + (m2/M)*r and y2= Y - (m1/M)*r
and ultimately, the answer to the problem
which is y1 = (L + (m1/M)*v0*t - 0.5gt^2) + (m2*v0/M*w)sin(wt)
and y2 = ( (m1/M)*v0*t - 0.5gt^2) - (m1*v0/M*w)sin(wt)
So you're breaking this problem into two parts: the motion of the center of mass, and the motion of the two particles relative to the center of mass.
The first one is a simple projectile motion problem, and you should use the equation you mentioned, y = c0+c1t-1/2gt^2. You need to calculate the initial position and the initial velocity of the center of mass, and plug these in for c0 and c1. The position of the center of mass should be easy, and for the velocity, use vcm = ptot/mtot.
The second part is the motion of two objects connected by a spring. Using the reduced mass equation you mentioned, you can find the distance between the objects as a function of time, and then you can use this to find the position of the objects relative to the center of mass, so that you can combine this with your previous result. The initial conditions here are the initial length of the spring and the initial rate of change of the length of the spring.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
